Old 10-01-2022, 10:18 AM
pilot737 pilot737 is offline
Default 67 GTO front seat replacement
Has anyone replaced 67 GTO front seats with new from TMIproducts?
They make complete replacements for many cars/trucks but not GTOs.
If you haven't done a complete (including frame) replacement, but did cover and cushion change, I'd like to hear about it.
Old 10-01-2022, 12:00 PM
1965gp 1965gp is offline
Does TMI sell just the cover and foam? That might make them more affordable.
Look at www.pro-touring.com there are a few 66/67 builds on there with TMI seats (I think).
Old 10-01-2022, 12:16 PM
66/67 GTO build? I've done several searches on that site... pontiac, gto and nothing comes up for me.
I don't see cover and foam on the TMI website for GTO. They do sell a complete "universal" seat but says "fabrication required" for the universal bracket.
Edit: I have gone through the 'rebuild' thread and see one now. The search feature on the pro-turing site is TERRIBLE.
Old 11-19-2022, 06:00 PM
cjs64goat cjs64goat is offline
I've done several TMI foam/covers on original and stock repo frames on F body seats. They are much firmer with higher bolsters and you set up higher in the car. If you're tall that can be a problem. With some of the aftermarket seats you will sit higher too. Partly because of adapters to bolt them in.
Old 11-20-2022, 03:25 PM
Thanks for that info. I'm 5'9" so the extra seat height wouldn't be a problem. With the TMI seat foam and covering that you've used... when you order, is it specific to Pontiac GTO? I'm specifically interested in 67 GTO.
Old 11-20-2022, 09:23 PM
Just Camaros so far. I haven't done the GTO ones yet. But was told they would be similar. Also if you use new springs or frames/springs assemblies then you will sit higher and they will be more firm too. Even putting original style covers on with new foam and springs can be hard. I have to use a bar clamp to compress the seat upside down on a table in order to get the hog ring on. Also many new covers use listings with a cord on the edge where originally they used a wire. They tear and give you "loops" between hog rings which you can see in the cover. So I take them out and put wires in again.
