tri-power acc pump size
on my 1965 tripower gto is there a different size acc. pump w/Viton seal for the center carb and outer carbs? thanks bob.
The accelerator pump diameter is larger on the end carbs in 1959~1965 than the center
1957 and 1958 all three are small. 1966 all three are large. Jon.
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
acc pump size
why I asked. when my buddy and me installed the acc pumps with the Viton seals with the garter springs the center carb worked great but both outer carbs stuck. so we put back the acc pumps we took out from the outer carbs and every thing ran well again. thanks bob.
The Kits have different pumps in them for the 65 and earlier carbs (1959), Center vs Ends. Why you need to be sure the guy gives you 1 'Center' kit and 2 'End' kits. I have had them screw me up on that deal if i wasn't paying attention.
Tom V.
