Industry Stuff new repro's, updates, other info.
Old 07-18-2015, 10:11 AM
rick c rick c is offline
Send a message via MSN to rick c
Default parts i would like to see
67-69 firebird clutch return spring extension for v8 cars. they make them for 6 cyl cars and tell you to modify for v8,s. I see goodmark makes one for the camaro small blocks and claim it fits firebirds,but someone said it needs modifying too.
  #1522
Old 08-29-2015, 10:04 AM
WWS WWS is offline
Default Parts I would like to see
die cast grill for '72 GTO
  #1523
Old 08-29-2015, 10:05 AM
WWS WWS is offline
anodized aluminum door & quarter reveal moldings for '66 - '67 GTO
  #1524
Old 09-02-2015, 10:39 AM
G20's Avatar
G20 G20 is offline
Die cast '64 GTO manual consoles. They are really hard to find.
'64 GTO Hardtop
Marimba Red, 389, Tri-power, 4spd car.
http://www.northwestlegends.com/
  #1525
Old 10-22-2015, 09:52 PM
Outback Jack Outback Jack is offline
Correct mounting hardware and bushings for the 73 Firebird core support and nose panel.
  #1526
Old 10-22-2015, 10:07 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default 63 Tempest Power Steering Pressure Hose
63 Tempest Power Steering Pressure Hose. If you have one please PM me.
  #1527
Old 10-22-2015, 11:00 PM
Formulabruce's Avatar
The lower mounting set that is sold by Ames works well, and I believe is better than stock. The only piece I see as slightly different is the "donut cushion" , but it works well. What exactly are you speaking about?> clips or?
  #1528
Old 10-23-2015, 12:15 AM
I would like to have patch panels for the rear 1/4 panel on a 73 GTO/LeMans as they are different then the 74-77 1/4 panels. Or even a complete 1/4 panel.
  #1529
Old 10-23-2015, 08:12 PM
Yes "donut cushions" and hardware including the special nuts. I only have one original lower rubber bushing and sleeve and one square metal nut with the tab on one side. Do you have to enlarge the hole in the core support for the new donut cushions that Ames supplies?
  #1530
Old 10-24-2015, 02:35 PM
Just got a set for a 1970 Im working on, and these have the correct size shaft in them, unlike earlier repops that were the size of the '73 units.
  #1531
Old 10-24-2015, 04:45 PM
hakansan's Avatar
hakansan hakansan is offline
I think the correct core support kit for 1970-1972 is S391.
Håkan
`70 GTO, 370 hp, 3:90, TH400.
  #1532
Old 10-26-2015, 08:01 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
These are available for hardtop. I suppose you have a Sedan(post) car? I think that's an item you may see at some point. .
  #1533
Old 10-26-2015, 08:05 PM
Ccass's Avatar
Administrator
Originally Posted by spieker View Post
I would like to see accurate repros of 64 thru 67 steering wheels for Lemans-GTOs. Both the stock and the optional pontiac custom ones. Can they be produced for under $1100? Hell yes!
We are doing the 67-68 Deluxe wheel as we speak. Price will be around $299/ea. If this is a successful project and sales are decent, we'll look at the 66, 65 and 64 Deluxe wheels (probably in that order)
  #1534
Old 11-03-2015, 01:55 PM
67TIGER's Avatar
67TIGER 67TIGER is offline
Question 67 GTO Dash Ash Tray Bracket Trim?
Does Ames Performance plan to carry this part anytime soon? I can't find a listing for it anywhere. The old PY Part number was RPI 357.
  #1535
Old 11-03-2015, 04:08 PM
melwff's Avatar
melwff melwff is offline
the 1971 and 1972 GTO use a "U" shaped piece of metal to stabilize the hood release rod where it inserts into the retaining clip on the hood latch. This piece typically breaks one arm of the "U" and appears to be impossible to find.
  #1536
Old 11-13-2015, 08:03 AM
coonhunter70 coonhunter70 is offline
69 LeMans front turn signal lens and rear tail light lens.
  #1537
Old 11-25-2015, 11:39 PM
se428bandit's Avatar
se428bandit se428bandit is offline
Interior for 1971-72 Ventura and grills for 1971-71 Ventura.
  #1538
Old 12-21-2015, 10:55 PM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
Default Firebird 400 Fender Emblems
These are needed for the 74's. I see Ames has the 350 ones listed (FC201M) for the 70 Firebird. They appear to be identical or practically identical to the 74 350 emblems, despite the GM part numbers being different.
The 400 emblems are the same style and angle/stud location as the 350 emblems. They could cross for the 70's and the 74's in the Catalog. Whoever is making the 350 ones for Ames should be able to make a nice 400 too.
Additionally, I would think some owners of other year Firebirds may be interested in them as an add on.
___________________________________
"Objects in mirror are closer than they appear"
  #1539
Old 12-31-2015, 09:10 PM
ponjohn's Avatar
ponjohn ponjohn is offline
1973-1974 Ventura Tail panel
  #1540
Old 01-01-2016, 05:40 AM
kvunck kvunck is offline
1971-72 gto hood in steel or patch panel for inner and outer 7 inches of front of hood
1971 gto radiator support
1971 gto fenders
