THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
What is this under master cylinder?
I am Changing the master cylinder on my 70 camaro. What does this thing under the master cylinder do? The front brake line comes from the master cylinder to this and then to the proportioning valve. It would be a good place to remove and install a linelock.
Distribution block/metering valve? Think it was 1970 only, or only a year or so. It matches the combination/proportioning valve used.
The Following User Says Thank You to Trevor78 For This Useful Post: | ||
https://www.musclecarresearch.com/gm...ing-seal-kit-1 |
If I remember correctly i had to hold the button in on the back of that hold off valve to bleed my brakes. Also theres another valve in the rear brake lines towards the back,,,right before the line turns and goes towards the rear cross member. This whole system worked together for 70 to stop rear lockup i believe.. I replaced both of those valves on my 70 because i started getting rear lockup. New valves fixed it.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' Last edited by scott70; 06-07-2023 at 07:05 AM. |
The Following User Says Thank You to scott70 For This Useful Post: | ||
