Old 06-12-2022, 03:50 PM
Bermuda Blue Bermuda Blue is offline
Default Crankshaft options - Made in USA
Lets say a guy can't stand Chinese parts and wants to build a 4.00", 4.21" or 4.25" stroke x 3.00" main motor. Are there any made in USA options for sourcing such a crank?
Old 06-12-2022, 04:00 PM
A Crower or some other brand of crank machined from a solid billet is probably the only made in USA option, and even then there’s no guarantee that the billet was USA sourced. Very expensive in the thousands and long lead times.
All the forged cranks come from China nowadays there’s really no way around that, finish machined either over there or in the USA.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 06-12-2022, 04:15 PM
mgarblik mgarblik is offline
As b-man said, Billet is the only true American choice and you would need to verify where the billet came from if that's important to you. Crower current lead time is about 6 months and approaching 4K now with all the price increases. A more budget friendly, sort of USA made and with good quality control may be a Molnar Crankshaft. The machining is done in the USA, and their quality control is excellent from my limited experience so far. Other Chinese cranks say the machining is done in the USA as well but that doesn't guarantee quality. Eagle, Scat and some others make those claims. No matter what, you as the customer will need to check it yourself or have a trusted machine shop verify ALL the dimensions when you get it. Good luck.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 06-12-2022, 07:13 PM
Thank you b-man and mgarblik for the quick and helpful replies.
Old 06-12-2022, 07:40 PM
Build it off of a 421, 428 or 455 block and drop in a factory 4.00”’or 4.21” stroke cast crank.
Plenty durable for most any Pontiac street engine up to 600 hp which should be more than sufficient.
100% USA made.
There’s no big advantage having a 3.00” main engine on the street.
I do get that at one time 455 and other 3.25” main blocks were hard to source and the more plentiful 3.00” main 400 blocks were one of the driving factors for the introduction of the 3.00” main stroker cranks. Now even the 400 blocks aren’t all that plentiful so I guess it’s a toss up.
Old 06-12-2022, 08:41 PM
b-man: I really like that idea allot, if USA made is the driving factor. 455 blocks are still out there. Friend of mine recently bought a pair of 455's standard bore with crankshafts, kept indoors for 2K for the pair. They look good.
Old 06-12-2022, 09:09 PM
Mike, the only Pontiac crank Molnar offers is a 3” main with 4.25” stroke. I know of a few people who asked the owner of Molnar about producing a 3” main 4” stroke forged crank at PRI. His comment was he needed orders to justify producing such a crank. I, for one, would purchase one in a heartbeat. The thought of investing several hundred dollars into a Chinese forged crank, just to have to invest several hundred more into it to make it useable doesn’t thrill me.
Dr. Thomas Sowell
Old 06-12-2022, 10:31 PM
I thought they had other options. Too bad. I thought Scat forged cranks looked OK but with the company being sold recently, no idea what the quality is now. Usually the first thing to go when a company is purchased are the engineers and QC people. That would concern me.
Old 06-12-2022, 11:20 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Molner does have other options, I again wrote and asked them to consider a 4" stroke crank for us.
https://www.molnartechnologies.com/d...-crank-shafts/
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 06-12-2022, 11:34 PM
tom s tom s is offline
If I had to have a US forged crank I would look fo a 990,cut down to 3 in and weld up the thrust.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 06-12-2022, 11:40 PM
They have added several Pontiac cranks since the last time I checked their website. The problem with any stroke over 4.375 is clearance issues in a stock Pontiac block. The aftermarket blocks don’t have this problem.
Dr. Thomas Sowell
Old 06-12-2022, 11:41 PM
Tom, in other words do a Smokey Yunick.
Dr. Thomas Sowell
Old 06-13-2022, 12:09 AM
Doing all that work on a 990 SD crank makes little economic sense just to end up with something that’s more or less equal in strength to a new offshore forging at probably 3 or 4 times the cost when you consider what the price of a workable 990 crank is nowadays.
If cost isn’t really a consideration then a worked 990 or a new billet are really your only USA made options if you’re not into running a cast factory crank.
As Tom would say, this is the street section.
I can’t imagine that a prepped factory cast crank couldn’t handle 99% of the hot real street Pontiac engine builds. There’s one member here running 9.40s with a turbocharged 2-bolt main 455 block and crank that’s been together for over a decade.
Old 06-13-2022, 10:02 AM
Im running 2 cars with factory 421 cast cranks,the one in my Tempest has been in there 22 years now and never out.It had been nitrited,does have Carillo rods and Ross pistons.Many runs over 6000,retired to a 100% street car.Tom
Old 06-13-2022, 10:13 AM
Tom, there is no doubt that Pontiac cast ArmaSteel and nodular crankshafts are tough pieces. I think nitriding just makes an already durable crank a little more durable. God knows the nitrided diesel cranks I have ground in the past were tough pieces.
Dr. Thomas Sowell
Old 06-13-2022, 02:13 PM
Johnny406's Avatar
Gentlemen,
Some of you have seen my post here and on Facebook with the same issue. I was recommended by a gentleman on FB to contact Dave Olsen at
Mile High Crankshaft in Denver (303) 781-6764. I spoke with him at length this morning and he can/will weld up the thrust area and turn down our 3.25 main cranks to fit a 3" main block. He's only about 100 miles from me and I will be taking a crank to him this week. Though he's never done this to a Pontiac crank, he's done it to many Chrysler cranks. I'll gladly share the results. Like most machine shops, he's a bit behind but this is an option.
The Following User Says Thank You to Johnny406 For This Useful Post:
Old 06-13-2022, 02:19 PM
73 TRANSAM 73 TRANSAM is offline
Mile High is a Top notch crankshaft specialist. Very nice people and very reasonable price too deal with.
The Following 2 Users Say Thank You to 73 TRANSAM For This Useful Post:
Old 06-13-2022, 02:29 PM
Tom Vaught's Avatar
Boost Engineer
Timkin Ball Bearing Steel is what Moldex Crankshaft and Bryant Crankshaft use for their custom Billet "Race Crankshafts".
Timkin is a USA company. They have been making very high grade crankshafts from this ball bearing material for many years.
The Butler Billet crankshafts were made using Timkin ball bearing material.
The 421 SD, RA-V and other forged Pontiac crankshafts were made by Kellogg Crankshaft using Timkin ball bearing USA material.
So there are STILL two sources for having a billet Pontiac crank made: Moldex and Bryant.
Tom V.
Old 06-13-2022, 03:39 PM
Dragncar Dragncar is offline
455 block, 428 crank, done. Properly done you will never, ever hurt them in a street engine.
Or you can pay big bucks to Modex, Bryant or Crower and get exactly zero benefit in a street engine except a lightened bank account.
Old 06-13-2022, 04:29 PM
25stevem's Avatar
25stevem 25stevem is offline
Tom, are you sure the 421 990 crank was a billet?
I had one for a while ( never used it) but I thought it looked to be a non twisted forging.
Unfortunately I have no pictures of it to refresh my memory!
I do stuff for reasons.
