Old 11-07-2024, 10:26 PM
SD421's Avatar
SD421 SD421 is offline
Default Thoughts On This Ring Gear & Pinion
I just picked up these 3.07 gears to swap out my 3.73’s for a more friendly rpm range.
Can someone look at these pics and tell me what you think?
I picked them up for $150 as they were listed in “great condition”.
Thanks, Don
ID:	642508   Click image for larger version
ID:	642507   Click image for larger version
ID:	642506   Click image for larger version
ID:	642505   Click image for larger version
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 11-07-2024, 10:31 PM
Formulas Formulas is offline
I dont see anything disqualifying i will just say its measurably harder to set up used gears not knowing previous backlash but doable
.................................................. .No One Ever Escaped Tyranny By Compliance..............................
The Following 3 Users Say Thank You to Formulas For This Useful Post:
Old 03-21-2025, 04:11 PM
71 Goatman's Avatar
71 Goatman 71 Goatman is offline
Agreed, after trying and failing in the past with used gears, only to get nothing but howling I now only purchase new. Replicating the previous backlash is a challange.
71 Goatman
Hot Rods & Horsepower.......A diease for which there is no cure.
71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming
Old 11-07-2024, 11:28 PM
Schurkey Schurkey is online now
Does the "2" represent pinion depth variance?
If not, getting pinion depth right will be a guessing game, which is going to make getting the mesh correct even more difficult.
Old 11-08-2024, 12:22 AM
SD421's Avatar
I haven’t a clue about the 2 stamped on the pinion.
1966 GTO
1966 Tri-Power
1967 670 Heads
Old 11-08-2024, 03:39 AM
lust4speed's Avatar
Photo #2 looks like the ring gear teeth are galled but I don't see corresponding look on the pinion teeth. Are those teeth as rough textured and pitted as the picture makes them look?
Mick Batson
Old 11-08-2024, 03:42 AM
SD421's Avatar
Here is a different section of the ring gear and a pic of the backside of the pinion.
ID:	642520   Click image for larger version
1966 GTO
1966 Tri-Power
1967 670 Heads
Old 11-08-2024, 05:58 AM
What the hell are all the punch marks on the face of that gear?
Old 11-08-2024, 12:02 PM
If it's anything like the similar marks on my Lumina camshafts, it's how they hold the part securely when performing the machining operation(s).
The Following 3 Users Say Thank You to Schurkey For This Useful Post:
Old 11-08-2024, 09:13 AM
AG's Avatar
AG AG is offline
The pinion depth is designated by a 2-digit code for that 12-bolt ranging from 40 to 50. A 45 designates a specific depth (can't remember what it is, have it written down) and numbers below subtract 0.001" per increment and digits above add 0.001" per increment. It can be stamped into the tip of the yoke end. I just checked a 3.07 12-bolt pinion and it is written (grease paint?) on the face of the gear on the bearing side and is a "45".
The Following 3 Users Say Thank You to AG For This Useful Post:
Old 11-08-2024, 04:53 PM
SD421's Avatar
No stamp on top of pinion but there is a “K8” Stamped on the body and maybe the green mark used to be the code?
ID:	642555   Click image for larger version
ID:	642554   Click image for larger version
1966 GTO
1966 Tri-Power
1967 670 Heads
Old 11-08-2024, 10:46 PM
AG's Avatar
AG AG is offline
In your third pic where it focuses on the snout of the pinion is where it is supposed to be stamped. If you look straight down onto the face of the gear below the gear is where mine is marked "45". I also have a 2.56 pinion from 1972 and I'll check that one to see where the number is.
The Following User Says Thank You to AG For This Useful Post:
Old 11-08-2024, 01:32 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Thanks, Don
Not impressed with the tooth face surface in photo#2. The wear pattern is even and covers most of the face indicating proper pinion depth setting, but the pitted surface tells me there were fluid issues from heat, contamination or probably dirt. The 2.73 that just came out of my rear end after 164,000 miles had same wear pattern, but the tooth faces had a polished finish to them.
The Following 2 Users Say Thank You to srmmmm For This Useful Post:
Old 11-08-2024, 04:08 PM
geeteeohguy's Avatar
I agree. I've had these opened up with well over 200,000 miles on them, and the gear teeth are as smooth as glass. This is with in-service rear ends on these cars (ones I've owned and customer cars). This looks like rust pitting or contamination. The teeth look rough. Can you feel the surface pits with your fingernail? Or is it just visual.
My opinion: the gears can be used, but may be a bit noisy. They are not 'junk'. You may not even hear them over the exhaust being dumped out of your Tribal Tubes from that tripower 421 you're packing.
Jeff
Old 11-08-2024, 07:44 PM
SD421's Avatar
It’s just Light rust
1966 GTO
1966 Tri-Power
1967 670 Heads
The Following User Says Thank You to SD421 For This Useful Post:
Old 11-08-2024, 08:09 PM
694.1 694.1 is offline
Buff that light rust with 400 grit.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 11-09-2024, 04:11 PM
I respectfully disagree. Maybe some 0000 steel wool at most. Never use sandpaper or emery cloth on a gear surface. At least I wouldn't.
Jeff
The Following 2 Users Say Thank You to geeteeohguy For This Useful Post:
Old 11-11-2024, 12:07 PM
Pontiac Performance Author
My first impression is the gears were media blasted to hide defects.
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 11-11-2024, 02:18 PM
lust4speed's Avatar
Yep. Took out the rust and left the pockets.
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 11-11-2024, 02:53 PM
Definitely media blasted to hide defects.
Looks like the ring gear is still dusted with blasting media.
No set of used gears should like like those ones pictured.
