trans am pacer car water pump hose ????
Hi
I have an 80 trans am pace car 301 turbo I am looking for the coolant hose that one side ( 90 degree bend) connects to the water pump and The other side makes a 90 degree bend and passes thru the ac compressor area Is the factory hose still available?? If not what are people using As Always Thank You |
a factory correct hose is not made as far as i last knew but you can probably find one for another car with a similar 90* bend around the a/c compressor to work. or you can try to heat & bend one a little to get close but probably wont be perfect. see if some of your local parts stores will let you look at what they have in stock.
went to parts store and found both bends and 2 steel couplers |
