head bolts,cam plates,eccentrics
I started cleaning the shop today and found I have a 100 or so used stock head bolts. These are bolts from motors I parted out over the last 30 years. I will try to make sets if there is a intrest in them. I also have lots of cam plates and fuel pump eccentrics.
no intrest at all huh.. off to the scrap yard.........
If you separated them into sets and put a price on them you might garner some interest.
Ok I sold a set to a guy here in town so im going to offer a few sets here. Im asking $30.00 a set $10.00 for a eccentric and cam plate if anyone has a need. I also have 10 oil pump shafts $5.00 each. Thanks B-Man for the post.
Do you have the bolts and washers for the cam plates and eccentrics, the big cam bolt with thick, flat washer and the plate bolts with split washers? Would you split the plates and eccentrics? I'd be more interested in the plates than the eccentrics. How many of these do you have?
Thanks, Troy
'80 Grand Lemans Was 301 C.I. Will be bigger soon. 00 GTP NBM / Graphite, Stock Sold Aug. 2011 70 GTO Black / Black TH400 460 CID, 542 FWHP, 580 FWTQ (Sold, Fall '09) 04 GTO Black / Black M6 Back to bone stock and sold, fall '05. |
I have 10 cam plates. I have the bolt and washer for the cam 10 of them also. Im sure I have the bolts and washers for the cam plates but I would need to look if you need some. But these are not hard to get from any good parts store.
I also found 10 or so crank bolts with the washers.
