What GTO in 1969 would have come with an idle stop solenoid?
How does it work? Is this correct: http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en |
I believe it is correct for the following: 1968 GTO/Firebird...1969-1970 GTO/Firebird Ram Air IV and 1971 GTO/Firebird with 4 bbl carb and manual transmission.
My pictures are of a original GM part. So, reproduction looks to be a good copy but no part number is stamped on it. Not sure how good they work though... |
I thought that was for automatics?
![]() Quote:
Manuals too.
![]() 69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
A 1969 400, non Ram Air, manual or auto, would not have one?
I thought it activated when the a/c was turned on to maintain idle speed and compensate for the increased load.
That solenoid could be used for either reason but in 69 it was only used only on RAIV's and Sprints and it was to prevent auto ignition (dieseling).
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
The seller has another one.
For AC cars, this solenoid engages when the compressor does, and bumps up the idle speed to compensate for the extra load on the engine. Hence why you sometimes hear it referred to as an "idle compensator". It would be triggered by a wire that gets power when the compressor turns on.
If it works as north describes (which is the way it's setup on early Corvettes - my '73 Stingray works this way), then it's actually used to set the idle speed. It's activated when the ignition comes on. The way you set it is to disconnect it and set your idle speed screw a few hundred RPM below the recommended setting. Then plug it in and turn the stop to set your idle speed at the desired RPM. It's a neat system because it allows you to run a slightly higher idle speed (throttle blades more open) if you need it, and when you shutoff the car it snaps the blades closed to prevent run-on (aka dieseling).
follow me on Twitter @albertpenello --------------- 1972 Firebird Formula 1965 Ford Mustang 1965 Oldsmobile 442 1968 Pontiac GTO 1968 Dodge Charger 1972 Chevrolet Vega (V8) 1973 Corvette Stingray 1978 Pontiac Trans Am 1980 Triumph Spitfire 1983 GMC A-Team Van |
![]() Quote:
