Old 04-14-2013, 10:18 PM
JimChevy JimChevy is offline
Question How do you remove seatbelt retractor cover??
I have a set of replacement retractor covers that I want to install but I'm not sure how to remove them. There is a phillips screw that won't budge! How do I get this screw out and when I do, is a spring going to fly out or what?? Thanks
"1969"
400/TH400 w/2100 stall
Auburn Posi
Ram Air Manifolds w/2.5" Flowmaster Super 44's
Quick Fuel 750 CFM
Expresso Brown/ Gold Interior
Old 04-15-2013, 10:27 AM
topless67goat topless67goat is offline
I did mine last year...same color.
I can't say why the screw won't budge. I think mine were tight but I was able to break them loose. As far as springs flying out that won't happen. There is a couple parts in there one of them being a spring which you'll have to wind while putting them back togther. Getting the proper tension may be a small challenge just get a feel for the tensions before taking apart and try to reproduce while putting back together.
Once you get that screw loose just remove the retractor assembly slowly and put it back together the same way it came apart. Make sure you do one at a time so as not to mix up parts. I took them apart at the same time and ended up putting the pass cover on the drivers side.
Old 04-15-2013, 12:38 PM
Thumbs up
Thank you sir! Sounds pretty easy, just have to get those screws loose tonight without stripping them!
"1969"
Auburn Posi
Quick Fuel 750 CFM
Old 04-15-2013, 04:58 PM
corellian corvette corellian corvette is offline
Use a little heat on the plastic retractor cover. Will help getting the latch out w/o breaking or cracking it...
follow me on Twitter @albertpenello
1972 Firebird Formula
1965 Ford Mustang
1965 Oldsmobile 442
1968 Pontiac GTO
1968 Dodge Charger
1972 Chevrolet Vega (V8)
1973 Corvette Stingray
1978 Pontiac Trans Am
1980 Triumph Spitfire
1983 GMC A-Team Van
Old 04-15-2013, 07:18 PM
I may have to try that if I can't get it free.
"1969"
Auburn Posi
Quick Fuel 750 CFM
Old 04-15-2013, 08:37 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
I did mine on my 69 GTO last year.
Since I was replacing the covers,I just made a note as to the direction the cover was facing and then just cut the darn thing off [plastic cover].
Then put the new cover over the buckle and do some hard pulling till the buckle come through...............worked for me.
color me gone
Old 04-16-2013, 08:53 AM
2002Z4CSS's Avatar
Use an impact driver to loosen the screw.
1971 Pontiac GT-37
Old 04-16-2013, 01:30 PM
+1 on impact. My body guy actually once showed me a simple trick. Hit the head of the screw a few times hard with a hammer. That will knock it loose and it comes right out...
1965 Ford Mustang
1965 Oldsmobile 442
1968 Pontiac GTO
1968 Dodge Charger
1983 GMC A-Team Van
Old 04-18-2013, 12:15 PM
Thumbs up
Update- I found out that screw doesnt turn at all because it has a deep groove running down the length of it that the spring housing rides in. It simply pulls out! When I did this the spring unwound. It took awhile to figure out how to reassemble the mechanism. I cleaned up the belt like new and reassembled the spring assembly by turning counter-clockwise ( this is what makes the belt retract) using a cordless drill on reverse. When I got the tension set I kept the drill bit in the screw head while I hurried up and put the nut on the other end of the bolt! I see no other way of doing this. I also pulled the belts thru the new retractor covers really hard to get them thru as 1969GTO suggested. I hope this helps someone else.
"1969"
Auburn Posi
Quick Fuel 750 CFM
Old 04-18-2013, 06:56 PM
1969GTO's Avatar
Default Glad I could help
I had no clue either when I did mine last year,I figuerd since I was getting rid of the old covers,just cut the darn things off,got lucky,it worked
color me gone
