What was the problem with your motor Hooter.
I didn't see any thing about on here. GT. |
Lost oil pressure on day 2 in Topeka last year. Upgraded to better oil pan and Mark Luhn oil pump. Freshened motor. Also changing to a set of non ported cv1 heads.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
As mentioned before, I plan on signing up the Skylark again. I may re-cam it this summer. Pull out a little duration and run up the lift and see how it does.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
I'm hoping to get registered. Love the tracks/route this year.
I am planning on it again....hopefully motor will be on the dyno in the next month...hopefully!
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017! |
Are you going to be running the same combo as last year or something new for this year?
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U |
Sorta the same....ish! Last year was a 455 block 4.25 stroke with 4.19 bore, this year it will be a MR-1A (aluminum) block, 4" stroke 4.25 bore, so more rev's, hopefully help the T56 Magnum survive (which last year I was running a TKO 600). the rest is the same, cam, heads, procharger. Oh the only other differences are a Advanced Clutches dual slider clutch, adding a oil accumulator, hydroboost....
Hardly any changes. |
Can't wait to see how your "454" does! How much weight difference between a 455 block and the MR-1A?
LOL! Are you making the trip again this year?
I sure would like to but am unsure right now.
I will start by trying to get registered and go from there. |
Greg, its about 100lbs lighter than a stock iron block.....Gordo ....just a few minor adjustments thats all....: )
Registration is next Saturday May, 2nd at 9:00AM Pacific time! Would be great to see a lot of Pontiacs get in again. It will most likely sell out in a few minutes.
http://www.hotrod.com/events/1504-ho...ion-info-here/
I'm going to try and wedge a Buick in there =P
One of these days I hope to see a Firebird with a turbo cammer 6 at Drag Week.
Got my twin turbo GTO registered! Who else is going?
I'm in again! Can't wait!
#38
It's about time one of you POSI guys got in on the drag week fun. I'm in also
#39
I am in as well!!! Look forward to hanging out!!
#40
Hey Rich - How many in your Drag Week clan this year?
