#81
with ALL due respect for EVERYONE on this post.I cant even think about going back to 44 year old tech!Raced one when they were the fad and pulled it and NEVER went back.IF and that is a big IF,I wanted to go to a auto,it would be a T-400.That day however is when 4 speeds are banned and someone removes my left foot!LOL,Tom
#82
I agree with stevep, that a Dual-Range is the way to go to build a really solid high-performance Hydramatic. But, having said that, I'm not sure I'd recommend it, as it's pretty expensive to do these days.
#83
It is pretty expensive and it is actually 1930's technology. But if you want a solid older automatic trans, it is the Dual Range all the way over the Dual Coupling.
But if you want a solid automatic that parts are readily available and can be repaired almost anywhere, than the 400 wins. But the Dual Coupling IS my favorite automatic transmission.
#84
#85
stevep--
So if the intermediate coupling is a major source of failure on the dual coupling super hydro, are there any performance "symptoms" particular to that mode of failure---anything to watch or listen for? Any other common sources of trouble? I notice occassionally on my 60 that the first shift isn't always consistent------seems too soon on occassion. Thx for any feedback. FWIW I never would have dreamed that this thread would generate so many responses-----thanks everyone for all the comments! |
#86
Brent,
Do attend Norwalk? I'll be there this year and I'll be glad to take you for a ride. I wonder how much less friction there is in a 2.56 rear end compared to a 4.56 rear end? Poncho, excellent thread!!!! Last edited by PITTSBURGH 64; 12-09-2007 at 02:50 PM. |
#87
Poncho,
If the internal coupling fails, you will only have 1st and 3rd. The coupling gives you 2nd and 4th. (One way to consider this trans is a 2 speed trans with a 2 speed tourque converter. The internal coupling replaced the front clutch on the Dual Range for smoother shifts, as the Dual Range would always "snap your neck" on the 1-2 shift and customers did not like that.) If your 1-2 shift is early sometimes, I would check the TV linkage at the carb first to see if it is sloppy or binding. If not it could be a problem with the valve body or govenor. Jeff, I hope that you STAY in Norwalk this year and NOT drive back and forth. Get your room NOW. There are plenty of places in Willard OH, which is about 20 minutes away, at VERY reasonable rates. If you stay, that's more time that you can spend there. And don't forget the Friday night PY BBQ! Think like an Italian (me) for a change! I also agree that this is an excellant thread!
The difference between inlaws and outlaws? Outlaws are wanted Last edited by stevep; 12-09-2007 at 03:10 PM. |
#88
#89
Jack,
Can the hydro stick be built for a street car with softer shifts? Damn would I love to have a shifter controlling all the gears! Do you install a longer manual valve to give the extra shift point? |
#90
The Hi-Rank book that Jack refers to has a number of modifications, but in general it says to do them all, without explaining what each individual one does.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
#91
Bill, Where can I pick up one of these books?
Are you related to the POCI tech advisor in Smoke Signals who passed in August? Poor guy, his tractor flipped over and killed him. Last edited by PITTSBURGH 64; 12-10-2007 at 09:12 PM. |
#92
Jeff, they are not written in Polish!
#93
How about backwards English then? My uncle Ziggy was a enigma code breaker you know....................
#94
LOL!! Maybe he knew my cousin Vinny??
#95
Edit: I just looked at some photoguides..... umm I dont think that car is going to be for sale its a 53' Eldorado. rare beyond rare........ Last edited by zbuickman; 12-10-2007 at 11:34 PM. |
#96
The book is good late night reading. I picked it up on eBay a few years back. Quote:
#97
Bill thank you, I may just take you up on it someday.
But for now I'm going to hunt for one on e-bay. I'm busy with the factory manual learning all the circuits and different parts. Glad to hear it wasn't a family member. I think a Pontiac guy on a tractor could be most of us. |
#98
First gear position is enabled by machining a new notch in the valve body's detent-sector-plate, between Reverse and the original 'Low', along with modifying the guts of the valve body accordingly- which I didn't have the "joy" of doing, since I simply bought a completely modified valve body from Hydromotive.
#99
Will the 55-56 dual range fit a 59 389 block?
This gear indicator must of been custom made. Last edited by PITTSBURGH 64; 02-17-2008 at 07:05 PM. |
#100
