I can’t find any info on it. But I’m considering getting it for my 455.
It's an old outdated Crane design. But pretty cool one popped up. I ran one in a 400 about forty years ago and it ran fine with a nice lope.
![]() Quote:
I’m considering it because it’s a NOS cam and I wouldn’t have to worry about the new cheap cores. But not sure if it’s too big for my stock 455 build. |
Gonna need some info on heads being used ... good cam for a stock 1970 #64 head 455 .... for a stock 1973 #4X head 455 ? not so much .
.................................................. .No One Ever Escaped Tyranny By Compliance.............................. |
my glasses must be do for an upgrade....for the life of me i cannot find the duration on that cam card ...where is it? lol
come to think of it i dont even see the lsa, but looking at the .050 timing, wouldnt that cam have 0 overlap meaning its probably a little on the small side? |
Good cam for a 455 with 9.5 comp.
If you have iron D port heads they will need to be set up for that cams lift even if you’re just running 1.5’rockers. Vehicle wise if you have a auto trans you will want a higher stall converter and a minimum of 3.23 rear gears.
![]() Quote:
But the advertised open/close numbers listed show something different? ![]()
Sales ad for that cam.....
https://www.ebay.com/itm/29681911800...tion=view_item Note same serial number on the cam card For interest try using the timing events calculator http://www.wallaceracing.com/camcalc.php .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
The Following User Says Thank You to Steve C. For This Useful Post: | ||
Not that it relates here but a VERY early Crane catalog listing for 57-78 Chevy has the SSH-310-NC as a single pattern HFT cam.
Adv 310 .050 236 114LSA .468 lift .
That is one of those old Crane cam cards that show the Asymmetrical closing ramps, they stopped doing that sometime in the 80s. I didn’t take time and do all the math but it roughly looks like it is 222*/232*@.050” tappet and ground on a 114* LSA with about a 110* ICL.
The top advertised number (left side column) is lobe lift (at the valve lift on the right side column with 1.5s and 1.65s). The next numbers below that are actual seat time number (310/320 @.0021” tappet with a 114 LSA and a ICL 114* (instead of the 110* that it has at .050”, which is showing the Asymmetric’s of the closing ramps on the cam. (EDIT) I missed the .0021” rating at first. It is rated at a lower seat rating than I recall. The 310/320 is very misleading. It is not a big cam I would not use that cam on a very high compression 455, 9.5 SCR would be about max in a 455 for pump gas. If you go higher compression than that there would need to be some extra engine mods. Preferably I would say 9ish compression with a 455, and a stock stall with highway gears would be ok as long as the compression is around 9. Reminds me some of a HC01 version HO enterprise's cam that had the wider LSA, that Crane mostly has less lift. Last edited by Jay S; 12-11-2024 at 10:31 AM. |
The Following 2 Users Say Thank You to Jay S For This Useful Post: | ||
![]() Quote:
The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
![]() Quote:
The Following User Says Thank You to Jay S For This Useful Post: | ||
"Ironic Crane screwed around more than any company with their advertised duration numbers and they're the ones recognized for coming up with the lobe "intensity" formula"
Intensity was a Harvey Crane invention and he had the hydraulic Intensity as the difference between .004" and .050". It has been stated 0.004” is the accepted estimate of internal deflection in a hydraulic lifter when the valve starts to open. Edit..... In addition Harold Brookshire stated both Harvey and he design Unsymmetrical cams, where the opening side and the closing side are different everywhere except at the nose. This now can involve the difference in intensity on the opening and closing sides of the cam lobe. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-11-2024 at 11:44 AM. |
Everything looks Greek before that first cup of coffee..... I think you are correct. Man last night I was coming up with 230.
![]() Quote:
![]() Quote:
You'd be light years ahead by getting a modern designed cam and having it Nitrided. Neither of those cams are designed to build cylinder pressure by today's standards and that is what a low compression 455 is going to want. Don't blame you for being skeptical but after all the dust settled "soft" lifters turned out to be the real issue. |
"We should also go through some information about opening and closing points as well. Each cam company calls out valve opening and closing points differently.
For example, a Comp Cams timing card >> will indicate opening and closing points at 0.006 inch of tappet lift. Crane delivers the opening and closing points at both 0.004 inch and 0.050 inch of tappet lift." Source: https://www.motortrend.com/how-to/14...camshaft-info/ This article was from 2003 Keeping in mind the Crane cam card presented here is VERY old and way before that timeline. So maybe the statement regarding Crane using 0.004 inch is not always correct. Note the cam card states "Timing checked with dial indicator at a tappet lift of .0021 Also the Wallace calculator for timing events states to Use Advertised Durations - usually at .006" .
Anytime your cam is pumping more then .425” lift and you’re running the needed spring pressure for a Hipo cam, then yes screw in rocker studs are needed .
Also once your cam’s valve lift gets to .460” or greater then besides the needed springs the valve guides need to be machined for more retainer to seal clearance and while that’s getting done top the guides for the use of positive seals. This is what you’ll end up with. One question I have about your heads since they do not have screw in studs is does this set of 4X heads have the needed 2.11” intake valves ?
i thought might be the lobe lift since across from it , the lift with rockers are shown.
maybe u need sone fresh glasses like this guy...lol
Thread Tools | |
Display Modes | |
