I would agree with that for the most part except now we have crap gas that makes them run leaner and hotter than back then?
Never ever did any of the 4 Pontiacs I owned back in the 70s run over 180 with a 180 thermostat installed. For that matter, never have any of the Fords I've owned.
Cause the temp sensor is on the hot side of the stat.
How hot do you think the coolant is coming out of the heads? Ever check with a temp gun?
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 Last edited by Region Warrior; 06-29-2011 at 06:02 PM. |
What side is that? the pass side? I have two sensors in my crossover one on the drivers side which is the factory gauge one , and then one closer to the pass side edge for my auto meter gauge and that one always show's hotter than the other is that why? I think why the older motors ran at 210 is cause almost all of them i think had the sensor in the head which showed the head temp and not the crossover temps.
Also as stated earlier, the Pontiac cooling spec I quoted states the stat begins to open at 190'. Now maybe the stat manufacture's build them to open at the stated value. But with a complete original style setup the engine is gonna run ~210 period! This would be "Normal" As a note on sensor location, all my sensors have been on the crossover with the exception of the '73 GP which is on the RH head. And this one, with the factory gauge, indicates the same temp results I've experianced with all the others. I am really glad I started this thread, since I am getting some really good info and thoughts from this. I just wish you or I could find a writtten factory referance to what is "normal". Or if we knew what temp the "idiot light" came on at least we'd know what was too hot!!!! DanC |
A guy I know who used to race stock cars said they made the most torque at 212 in his dirt car with a 400.
Not until the pump was replaced with an inferior one did it start giving me problems. Finding that screw up and fixing it (after MANY wild goose chases), cleared that problem and it does not get hotter than 185 with a 180 thermostat in it. This with a CALIBRATED Rally setup now. Charles |
We need that Pump Charles
We are WORKING on it as HARD as we can, Dude.
Something is in the works, we'll let you guys know ASAP. Charles |
The 1972 Pontiac Service Manual states that the Indicator light will come on at 248*F +/- 20*F. So it will light up anywhere between 228*F and 268*F...... These operate off of a thermal switch located in the passenger side head on the '72 350. Karl |
Same for 67 Karl.
Except it's on the intake. Any where close to that and the performance of the engine tells you WAY before the light comes on! When the light comes on, it's already too late, unnecessary damage has already been happening! That is exactly why the thermostat in mine is a 180°. I want the "cushion". As the "calibrated" gauge shows, the system IS performing as required. Charles |
You guys running 3 or 4 core radiators? also how much power u making? I am running a 3 core, and would like to find a 4 core for my 560 hp monster. I see oreily's has a new murray 4 core for 189
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's Last edited by grandville455; 06-30-2011 at 01:07 PM. |
I will definitely get one of the blueprinted water pumps/plates for my beast, but I'll eat my Evans pump if it makes one degree of difference in running temps. |
There's ok, good, and better SW gauges. Had a set of "ok" years ago. O/pressure was off by 10 lbs. Wtr temp by 15. Check out Formulabruce's post #32 on "Engine Temperature" thread.
Have you conferred with the engine builder as to what he would recommend? Or did you do it yourself? Quote:
Charles Last edited by Old Goat 67; 06-30-2011 at 01:55 PM. |
Yea that's a little different then my 560 hp trying to be cooled by a 3 core, actually my 195-200 running temps down the highway at 3100 rpm's doesn't seem to bad then for what i got! If I get a 4 core it will be that much better
#38
You do good boy! |
#39
Running Hot @ 210 Overrated
After reading all these really interesting posts, I still feel that 210/220 "running hot" is overrated. I base this on my experiance as well as Pontiac printing that the system is designed to run in excess of 200', designing a "Hot" light that illuminates at ~248 ( thanks Karl ), and a couple folks stating that their et's are best at 210'. So with that said I feel fine about running 210. If others are/were worried about running about the same, I hope this thread eases their mind and saves them a buncha money trying to get down to 190 cause they think they have to. Now if one wants to that's their prerogative! DanC Last edited by DanC; 07-02-2011 at 08:01 AM. |
