Sweet project! Have some catching up to do reading Steve's posts, & will keep an eye open for your progress!
AM/FM Monaural Radio back
Best Regards Thomas ------------------------------------------------- 1969 GTO Judge HT man 1969 GTO Judge HT aut (project) 1972 Trans Am 455 HO (project) 1973 Trans Am 455 |
Found the subframe far back in my storage today. The subframe is dirty but solid and will clean up well. I am planning to paint it semigloss black next week, or should I consider powder coating?
My Engine builder will start with the power-plant next Saturday, most of the parts seems to be there but still have a couple of boxes to go through. Please comment if you see something that looks wrong for this 72 TA Aut non Utilized Air car. Found a stainless plate (picture 3) that I couldn't find a place for directly, will dig in to the manuals
that part in your third picture looks like the heat shield for the starter solenoid. -James |
You're right about the heat shield James, the first time I've seen one IRL. Thank you.
The old 455 is now delivered to one of our best engine builders, will be interesting to see what the effect numbers will be after his treatments. The recipe is original with a little more camshaft.
Engine parts starting to be delivered. Best so far is a beautiful 7042270, thanks fellow PY member. Cant wait to get the engine up in the dyno.
Itīs Alive
Finally the engine is back together after more than 20 years in boxes.
Specs: 4.21 bore, 9.6:1 comp, Crane hydraulic roller 289621, Eagle rods, Ross pistons, everything else stock 455HO -72 (heads, intake, carb, distr, exhaust etc.) The objective with the build was to get a stock feeling in an AC, 3.08, aut car with some extra bite. The engine shows great power, starts and idle like a dream, 520.3 LB-Ft & 418.1 Hp in an restrictive low side dyno. I am really happy with the results Thanks Lennart, Kenth and Konolaracing for great help with the build. Next paint and detailing (yes, the bolts that are not correct will be changed to the original ones). Regards Thomas
Very Nice Thomas. Thanks for posting. Lots of original pieces made it through intact all these years. Congrats on your neat car!! Keep posting pics of the build as it looks top quality so far.
http://www.gt-37.org/gallery/main.php?g2_itemId=1085 Quote:
Hmmmm, 520ftlbs/418HP..... Those are some pretty nice numbers Brannon. Did you have the stock exhaust manifolds on the engine for this dyno run? I wonder if my engine builder will be able to touch those numbers????
http://www.starspangledbannerchallenge.com/ |
for the compliments and 165th for the links and input about the subframe. The great pictures of the restored subframe in your Flickr is great inspiration. Keep them coming . Right now i am up to my ears with work and waiting for some small parts before it is time to paint the engine. The body will be mounted in the rotoserie in a couple of weeks.
The exhaust manifolds is stock and the downpipes 2 1/4". I am still looking for pass (right) front fender 70-72. I really nice couple of later model could also be interested as donor.
Best Regards Thomas ------------------------------------------------- 1969 GTO Judge HT man 1969 GTO Judge HT aut (project) 1972 Trans Am 455 HO (project) 1973 Trans Am 455 Last edited by Brannan; 03-12-2012 at 03:37 AM. |
The dream is still alive
Slowly, actually extremely slowly the bird is coming back to life.
The Following 2 Users Say Thank You to Brannan For This Useful Post: | ||
Was your 72 California Car built/born at the Norwood Plant ?
You have it looking really nice with the quarter panel and tail panel replaced. |
That's purdy. Slow, but done to a high level is far better than quick and slapped together.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
Yes, Norwood car, we tried to color match and simulate the factory oxide, looks a bit red on the photo but i think we are fairly close, will be better with the overspray in place. The body was like a dream to work with, 0 rust and only GM panels front to back.
