Steering components same as Nova?
Are the tie rods, adjuster sleeves, and idler arm on a '72 Ventura the same as on a '72 Nova? I got a front end rebuild kit for a Nova and the diameter of everything is smaller and the idler arm is not the same at all. The bushings and ball joints fit fine.
Bill |
I believe the 71-74 ventura is unique in its steering components.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
I thought I recall that the nova has the steering components on the front of the knuckles and ventura on the rear of the knuckles (or visaversa)
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi |
Is the Nova power steering box the same as the Ventura? How about the pitman arm? I already have Nova tie rods, adjuster sleeves, and an idler arm. So if I get a Nova center link and pitman arm it looks like everything should work.
Bill |
The linkage will fit if you change all of it, as you said. The steering box is the same. For some reason, Pontiac used a curved Pitman arm (at least on every Ventura I have seen). Someone told me that was for exhaust clearance, but I have put 2 Pontiac engines into Novas of the same vintage, and had no problems clearing the steering linkage.
Importsmasher |
