Understanding Cam events
IF the cam card reads ABDC 104 deg, and ATDC 116 deg. Does that make the ICL 110 ( 104+116=220 divided by 2=110.
And if installed “ straight up “ that would put the cam’s icl at 110? |
Can you post up your cam card. ABDC is IVC and ATDC is EVC.
Stan
This an Ultradyne cam card?
If so, ABDC and ATDC belong to the numbers in front of them. Last numbers on each line are lobe centers. And that's why your lobe sep math worked out right. If the cam doesn't have any advance ground in... Dots up is the same as straight up. Clay |
Stan here is what I'm talking about
That cam has 6° advance ground in when installed "dots up".
To install it "straight up", ICL would have to be degreed to 110°. Clay |
Pontiac is both "dots up".
A cam with no advance ground in will have the same numbers for ICL and LSA. Your cam could be installed "straight up" but it would need retarded 6°. Straight up and dots up can be different or the same depending on the cam. They do get confused or used wrong regularly when talking about cams. Cam |
Thanks, that's the answer I needed.
Interesting cam card. I know that UD cams are asymmetrical.
I get the 72 degrees overlap and 287 degrees Intake duration and 295 degrees Exhaust duration, but I also get 105.5 ICL, 113.5 ECL and 109.5 LSA. Stan PS: I believe these are your lobes. Master___Adv_____0.050_____0.200_____Lobe_________ _________ Number_Duration_Duration_Duration____Lift_____104_ ____106_____108_____110_____1.5_____1.6_____1.7 ROLLER_Profiles_Adv_=_.020" --------- These_are_original_designs_with_slower_ramps_and_s tandard_valve_lash_.026-.030 --------- R81______287______254_______173_____0.3883___0.123 ___0.115___0.107___0.099___0.582___0.620___0.660 R88______295______262_______180_____0.3883___0.140 ___0.132___0.124___0.116___0.582___0.620___0.660
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 11-27-2020 at 06:13 PM. |
Stan I think I my have made a mistake about the 72 * of overlap. Pleasecorrect me if I’m wrong. |
38 + 34 = 72. Stan
these days we use vvt
It is easier to fool a man than it is to convince he has been fooled |
