#5241
They should have them.
#5242
SD starter heat shield, TMI!
According my 1974 FB assembly manual (page) UPC 6Y2 sheet 1, item #8 part# 466430 Shield D/LS2.
Unless I'm mistaken, D/LS2 would indicate not used on super duty starters . W/LS2 would indicate used with LS2 starter. My recent personal experience of trying to fit an OEM Pontiac double layer metal starter heat shield, as shown below, on my super duty was negative. Did not have enough room.
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth! |
#5243
My 74 SD had a shield.
(I still have it somewhere I think, buried though) The 'D' does not mean delete? Forget what it means off-hand, though. (they used some strange initals for a lot of things in there)
#5244
Shield
Does it look like this?
I’ve installed one, fits fine
#5246
#5247
Direct quote "I did not have a heat shield and suffered heat soak all the time until I added one".
#5248
Would have thought the manual tranny would have one for sure?
(mine was automatic) What month was it built?
#5249
I think June or July 74, I know he had to wait several months to get the car. He also said his original starter has never been replaced and it is a 1108500, a different number than you normally hear of.
#5250
Just to clarify, I ment to say original 74 "SD" TA 4 Speed owner. I left out the important letters, SD!
#5251
Put a heat shield on it and move on. The ambiguity of the responses so far tells you all you need to know. We all know it needs a shield and no one knows whether it had one or not. No judge will be willing to crawl so far under your car to knock off points based on this, but when you stop to get gas you’ll be happy you had one. Next...
#5252
Shield
Just found the part number of the shield looked it up and states it`s for 75 and newer. Not worried about judges bent wheel so I don`t think I`ll be moving on just yet but thanks for the encouragement, maybe you can if you don`t have anything positive to post. I like my cars to be as correct as I can make them for my own personal satisfaction.
I'm pretty sure his buddies are bidding it up for him, because nobody in their right mind would pay over mid-20s for all this would they? Anyways, I figured I would post it here on the off chance somebody out there has a '74 SD T/A in Admiralty Blue with a white interior with NOM. The background pic shows the car itself back in the day before he sold it.
https://www.ebay.com/itm/263544973538?rmvSB=true Last edited by starlightblack; 03-15-2018 at 01:22 PM. |
#5254
PIC OF THE '74
#5255
The fog lights are awesome!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#5256
Can anyone please post a picture of a stock super duty motor spark plug wire lay out. Or something similar. Thanks.
#5257
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
#5258
Here is a 74 Admiralty Blue SD car that is missing it's original engine, although it does not have white interior....
https://www.hemmings.com/classifieds...y/1909155.html |
#5259
AND a big trash can for the HOLLEY , the dash timing adjuster, The MSD BS under hood Valve cover and studs, or wing studs air breathers in valve covers, the spark plug wires. IF one is trying to impress with what it once was, why go "off the path" so much? people with a Jegs catalog get bored too often LOL all>. IMHO |
#5260
73 SD Formy vinyl top
Thread Tools | |
Display Modes | |
