Old 12-01-2020, 12:04 PM
Scott65's Avatar
Scott65 Scott65 is offline
Default Bronze Distributor gear question
Any of you ever encountered a bronze gear that was only drilled on one side for the roll pin? Whats the best way to try to take it apart? Preferably without destroying it... And just fyi, I didn't install it this way, it came on a used distributor already installed.
Old 12-01-2020, 12:51 PM
charlie66's Avatar
Could id be screwed in? Maybe an easy-out bit ?
My Half AN Injun.....
Old 12-01-2020, 01:03 PM
Scott65's Avatar
Charlie, its not screwed. Its a regular roll pin driven in from the available side, with no hole on the opposite side to drive it out. I can get it off, but was hopeful someone had a non destructive method that had worked for them. I'm pretty sure I can shear it if all else fails. There's at least some chance it could be salvaged that way.
Old 12-01-2020, 01:16 PM
Run a small (size right) bit through the center and make your own access hole.
After you get the pilot hole drilled.. Open it up just enough to drive the pin out.
Then study about sizeing it right for a longer pin
Clay
Old 12-01-2020, 01:22 PM
Scott65's Avatar
Thats something I can try for sure. Thanks
Old 12-01-2020, 03:46 PM
Scott65's Avatar
Inside of roll pin is evidently just un uniform enough to cause issues. Broken drill bit made it necessary to shear the pin. Its off. Gear won't be easily salvaged, but I have another. Now on to building new cam synch with it.
Old 12-01-2020, 08:34 PM
68azbird 68azbird is offline
wood screws?
It is easier to fool a man than it is to convince he has been fooled
Old 12-01-2020, 09:06 PM
charlie66's Avatar
Originally Posted by 68azbird View Post
wood screws?
No?
Old 12-01-2020, 09:08 PM
charlie66's Avatar
I would of tried pulling it out with a screw or a small easyout
Old 12-01-2020, 10:24 PM
Scott65's Avatar
I would guess anything that increased the interference, such as any ez out or screw would be futile. The broken drill bit dictated my course of action in the end. Baffling to me why it was a blind hole to start with...
Old 12-01-2020, 10:29 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Is there enough of the roll pin sticking out so that you could spot weld a nut to it?
Then you could possible pry or pull it out the way it went in.
Old 12-01-2020, 10:32 PM
Scott65's Avatar
There was very little, and it was close enough to the shoulder that it would've been challenging. Its done now, I sheared the pin. Gouged the bronze bore, but otherwise its ok.
Old 12-02-2020, 08:57 PM
charlie66's Avatar
Maybe it was a mistake at the factory?? It is weird!
