Old 02-14-2021, 09:48 PM
Formulabruce's Avatar
Default Formula wheel collars
Did not want to pollute the for sale section with pics, but thought you would like to see this batch that are boxed and going out on Tuesday to a member. PO is closed on Monday. added close up pic. If the collar has Not been recently painted or chemicals used, they come out really nice. The metal can absorb some chemicals and then its a bit tough to get them absolutely perfect. These are better than NOS or originals by far and will stand the test of judges and time.
ID:	560780   Click image for larger version
ID:	560781   Click image for larger version
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 02-18-2021, 01:44 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Bruce, what did you use to spray those? Rattle can wrinkle paint or is that a mix sprayed from a gun? Looks excellent.
Old 02-18-2021, 07:28 PM
Its hi temp adhesion promoter and then they are Hot flocked.
