Old 08-11-2009, 01:32 PM
UPC-WU2's Avatar
UPC-WU2 UPC-WU2 is offline
There weren't any GT-37s built on the coupe bodystyle in 1971. They were all hardtops.
1971 GT-37 - 350/M38, Rosewood Metallic/Black
www.GT-37.org
  #42
Old 08-11-2009, 01:48 PM
Jack Peters's Avatar
What UPC WU2 said. Coupe was in brochure but mirror interfered with wing window or maybe wing window interfered with mirror. The mirror was an add on in '71. HT, Conv and sedan door skin should be the same. It is the frame on the sedan that is different.
JLP
  #43
Old 08-11-2009, 01:50 PM
1971 T-37's Avatar
1971 T-37 1971 T-37 is offline
"The GT-37 option was available on two-door coupe and two-door hardtop." from GTOalley.com
There is so much conflicting information on the internet about this.
The quote I was refering to from GTOalley.com
"The 1971 Pontiac catalog shows three T-37 2 door hardtops, coupe and 4 door sedan. The catalog says "order one of these with a V-8 on either the coupe or hardtop coupe and you can turn your T-37 into a GT-37".
So the things I know. My car is a 71 coupe 2 door it has a factory 350/350 in it with a 2 barrel carb. the car flies T-37 flags. The vin is 233 27. 233 is for T-37 27 is for 2 door coupe.
I was just curious, based on the information found on GTO alley, if my car is a GT-37. According to what I read on the GTOalley.com site it should be but it flies T-37 badging.
Just a bit confused
thanks
  #44
Old 08-11-2009, 05:09 PM
Inagaddadavida_loca Inagaddadavida_loca is offline
Sometimes advertising is not entirely correct.
And GTO Alley is a crappy website anyway.
I just don't understand the mirror issue. It certainly does not explain *why* the GT-37 wasn't available as a coupe.
  #45
Old 08-11-2009, 05:34 PM
1971 T-37's Avatar
that's true so is it also correct that the 71 GT-37's had hood pins? I don't believe half the crap I read on GTO Alley. It does state it in the advertisement but it may not be entirely correct however I know my car had a side mirror and it has the wing windows as well
  #46
Old 08-11-2009, 07:27 PM
GTO Alley is wrong. There were no '71 GT-37 post cars. I have the original Pontiac brochure that shows one. Then never made them as per the problem with the wing window and the sport mirror.
I ordered my T-37 new. I was not interested in the GT package.
The GT package consisted of the following on any 2 dr ht T-37 when ordered with ANY V-8 engine.
Hood pins
Dual Exhausts w/chrome tips coming through valance panel
GT identification on fenders and trunk
Ralley II rims w/o trim rings
G-70 X 14 raised white letter tires
HD 3 speed trans w/hurst shifter
Stripe package
My catalog shows a sedan T-37 w/stripes and wrong tires but leaves out the coupe statement. it says "Order one of these V-8's in the haedtop coupe and you can turn your T-37 into a GT-37" This is a later '71 dealer brochure.
Suggest you go back and read ALL of the T-37 and GT-37 threads by doing a search here to get more information. This has been hashed out in the past. I think I did give the links earlier in this thread.
In another ad it talks about the coupe. This brochure is dated 8/70 for the '71
All I know is you couldn't get the GT-37 in the sedan.
JLP
  #47
Old 08-12-2009, 07:46 AM
2002Z4CSS's Avatar
Originally Posted by 1971 T-37 View Post
so according to the information provided on the GTOalley site the fact that my car was ordered with a V8 and is in the 2 door coupe body it is a GT-37 but he car flies T-37 badging. I am confused now.
Do you have your PHS documentation?
1971 Pontiac GT-37
  #48
Old 08-12-2009, 11:24 AM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
This would be the way to determine if your car was ordered with the GT-37 option. Just because the T-37 had an optional v8 doesn't automatically make it a GT-37. In fact, if you checked off the GT-37 option you were required to select a v8 engine. But if your T-37 only had an optional v8, it's still a T-37. Not that there is anything wrong with a T-37
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
  #49
Old 08-13-2009, 02:08 AM
What gloryrestoparts said. The GT was an option and was not automatic when a V-8 was ordered in a 2 dr ht. Mine is a T-37 and is NOT A GT. I didn't want the flash I just wanted the go.
JLP
  #50
Old 08-15-2009, 12:28 PM
gto4door's Avatar
gto4door gto4door is offline
Here is a '70 w/400, auto and A/C for sale in the Sacramento CA Craigslist. I've posted the pics of this car from the ad so when the Craigslist link expires, we will still be able to reference the photos.
http://sacramento.craigslist.org/cto/1323410783.html
ID:	178138   Click image for larger version
ID:	178139   Click image for larger version
ID:	178140   Click image for larger version
  #51
Old 08-15-2009, 12:37 PM
gto4door's Avatar
A '71 w/350 4spd on Detroit MI Craigslist. Probably an early '71 model with the eyebrow stripes since the GT-37 emblems are on the front fenders
http://detroit.en.craigslist.org/mcb...300379734.html
ID:	178142   Click image for larger version
ID:	178143   Click image for larger version
ID:	178144   Click image for larger version
  #52
Old 08-17-2009, 08:44 AM
2002Z4CSS's Avatar
I seen that one too! Looks to have a very plain seat material.
1971 Pontiac GT-37
  #53
Old 08-17-2009, 09:24 AM
This car does not have the optional vinyl interior.
JLP
  #54
Old 08-21-2009, 02:52 PM
Huds71 Huds71 is offline
I'm a newbe at this.....I have a March 71 GT-37, 3-speed 350 2bbl built in Freemont.
My car only needs two things......Time and Money.
1971 GT-37 350 2BBL 3spd Lucerne Blue/Black Int.
  #55
Old 08-21-2009, 05:52 PM
What color?
  #56
Old 08-22-2009, 01:29 PM
Just looked at GTO Alley about the GT-37. They mixed '70 and '71 together. Also the ad at the bottom of the page is one I posted here (I think or somewhere) several years ago and it states HT only. It is a '71 ad.
Sent them a message to try to straighten them out. We'll see if they do anything.
JLP
  #57
Old 08-22-2009, 04:46 PM
They won't do a thing, I bet - that site has been on cruise control for years.
I saw it as a source for reference for a GTO buyer's guide a few months ago. I almost lost my lunch.
  #58
Old 08-24-2009, 08:21 AM
2002Z4CSS's Avatar
Post some pictures of this GT-37.
1971 Pontiac GT-37
  #59
Old 08-24-2009, 10:08 AM
Judge273's Avatar
Judge273 Judge273 is offline
Isn't there a good GT-37 website??
Mike/Illinois
  #60
Old 08-24-2009, 11:58 AM
I know UPC-WU2 is working on one.
TH400/3.08 open
