67 GP Headliner
I need to replace the headliner in my 67 GP it is the perforated design and Gold color. I checked a parts supplier catalog and did not see Gold listed as a color. I think Gold was one of the more popular colors. Can anyone recommend a source?
If unable to find the correct replacement mine is in good shape but has some "staining" around a few edges. Any suggestions on possibly cleaning it? Thanks. Mark C |
I could not find the correct perforated gold for my '66 GTO back in 2005. We had to dye a white one with vinyl dye before and after installation.
If yours just has staining from when the vinyl roof used to leak, I would suggest going with the dye route while it is in the car. You might only have to do the stained areas and blend it, or it might be easier to do the whole healdiner. This will also work for the door panels etc. |
i think opgi carries that color
1967 pontiac bonneville 4door ht 400 ci |
Thanks! I will check OPGI.
Andre what was the brand/name of the dye you used for the gold color? What procedure for appylying it? Mark C |
I'll check the brand name as I have some left over paint. I think Steve used his multipurpose gun or touch up gun. (spray)
