Old 02-11-2024, 12:43 AM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
Default aluminum heads such as edelbrock
Hi
i'm curious, i assume the stock chrome pontiac valve covers do not fit on any of the kre, edelbrock,speedpro, etc manufacture heads even with thick gaskets?
never seen anyone run them...
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 02-11-2024, 01:09 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have a set on some E heads on a new motor! Clear HS rockers fine with a thick gasket.
Skip Fix
Old 02-11-2024, 01:45 AM
Thumbs up
They fit just fine.
Edelbrock heads shown below.
Old 02-11-2024, 01:48 AM
kyle_blake's Avatar
thanks again! that is awesome news!!! have a great weekend everyone
Old 02-11-2024, 04:45 AM
Same with the KRE's.
Old 02-11-2024, 06:53 AM
mrennie's Avatar
mrennie mrennie is offline
With KRE heads from SD Performance and 1.65 Crower stainless rocker arms, I was getting a very light tap and kiss marks on my reproduction chrome covers with the thickest gasket. Ended up adding a 3/8" cover spacer and thin rubber gaskets and problem resolved.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
The Following User Says Thank You to mrennie For This Useful Post:
Old 02-11-2024, 07:44 AM
steve25 steve25 is offline
I wonder if your repro covers are shorter then OEM?
Does your motor run longer push rods?
Old 02-11-2024, 08:43 AM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
As the others have stated... OE replacement covers will work. This is KRE heads, full roller valve train. Spacer and thick gasket was used.
1966 GTO Resto-Mod. 2nd owner California car, factory Air, Power Windows, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R, Yank 2400 Stall Converter, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust M, Continental Extreme Contact DW
Old 02-11-2024, 11:04 AM
tom s tom s is offline
I have never had to use a spacer with the aftermarket 69-70 type covers.Just use the 5/16 thick gaskets.That is with 600 plus lift and 1.65 H&S roller rockers.FWIW,Tom
The Following 3 Users Say Thank You to tom s For This Useful Post:
Old 02-11-2024, 12:31 PM
mrennie's Avatar
Valve covers looked the same as OEM but I did not measure them or compare side to side.
Pushrods are 9.150".
It wasn't all the rockers that touched, just one at each end of the head.
Michael
Old 02-11-2024, 04:09 PM
Tim Corcoran's Avatar
Butler sells various thickness valve cover gaskets including the 5/16 that is mentioned above and a 3/8. A 3/8 thick gasket is pretty thick and in most cases would eliminate the need for a spacer.
Tim Corcoran
Old 02-11-2024, 05:06 PM
cnc's Avatar
cnc cnc is offline
Tom where are these covers from ...Ames or...and part number if possible..
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 02-11-2024, 06:26 PM
jerry455 jerry455 is offline
I am going to be using those covers also. I have Edelbrocks, 9.050" pushrods, PRW stainless rockers and .600" lift. I will use either thicker gaskets or spacers, what ever is needed. I want to keep a "stock" looking appearance.
