Old 03-31-2021, 12:09 PM
grivera's Avatar
grivera grivera is online now
Default 69 Firebird with Tilt Wheel Ignition Switch GM Part Number?
Can anyone advise the GM Part number for the 69 bird ignition switch WITH tilt wheel?
All I see available are compatible with GM 1990093 - which excludes Firebird
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 03-31-2021, 01:02 PM
My Parts book says for 'All' ?
Old 03-31-2021, 01:21 PM
grivera's Avatar
Interesting - A few eBay ads explicitly say GM 1990093 is not compatible with Firebird. Our host doesn't know the cross reference to the part number they sell either - only their internal part number.
This shouldn't be this difficult!!
Will Rivera
Old 03-31-2021, 03:07 PM
Tim john Tim john is offline
Tilt is a very specific switch and bird only. A original GM switch is green in the pin connection area. I have a NOS in the original Delco carton, I can take pictures if you need for reference. I may have two NOS, can't remember.
Tim john---
Old 03-31-2021, 03:20 PM
grivera's Avatar
Thanks - if you don't mind the picture of switch and carton w/numbers will help.
Will Rivera
Old 04-01-2021, 03:32 AM
A Schab A Schab is offline
The 093 switch fits 1969 A and F body Pontiac’s and 1970 A body Pontiac ‘s. I’m not sure about the big cars. It’s easy to ID. at a glance because it’s cast in green plastic.
Old 04-01-2021, 07:54 AM
Here are several photos of a NOS ignition switch for a 69 Firebird with a "Tilt" steering column.
* Take notice of the "Green" colored insulated housing.
Tim john---
ID:	563831   Click image for larger version
ID:	563832   Click image for larger version
Old 04-01-2021, 07:59 AM
Additional 69 Firebird tilt column ignition switch photos.
I hope these photos are helpful.
Tj-
ID:	563834   Click image for larger version
ID:	563835   Click image for larger version
Old 04-01-2021, 08:08 AM
Instructions.
Tj-
ID:	563837   Click image for larger version
Old 04-01-2021, 09:18 AM
grivera's Avatar
Excellent - thank you! I ordered a Borg Warner (CS-75) part that cross references with that part number - advertised as made in USA. Hopefully it works as intended.
Will Rivera
Old 04-01-2021, 09:32 AM
Will, you have yours off and a pic of it?
Usually the tilt is opposite of the non-tilt.
Like a mirror image of it.
Old 04-01-2021, 12:40 PM
grivera's Avatar
I can get a pic and post it
Will Rivera
Old 04-07-2021, 08:58 PM
grivera's Avatar
Here is a pic with the old one (DelcoRemy) on left and Borg Warner CS-75 on right
ID:	564272   Click image for larger version
Will Rivera
Old 04-07-2021, 09:28 PM
Looking good!
