Old 03-01-2021, 12:42 PM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
Question F-250 18 x 10" steel wheels?
Trying to find a plain jane steel wheel for my 2002 F-250, in 18 x 10, or even 20 x 10. 8-lug x 170mm bolt pattern, 125mm center bore. There's hundreds of strange looking aluminum wheels out there, but as far as I've found nothing in steel. I'd get the factory 2010-2016 18 x 8" steel, but wanting to run 11 to 12" of tread width and that's too much rim squeeze. Also, does anyone make a kit to manually shift the transfer case? Tired of the screwy Ford electronics.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 03-02-2021, 05:18 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
Try a salvage yard that deals in heavy trucks, often then have heavy end one tons for commercial use that are more plain Jane.
As for Fords electronics, they do suck. I’m not sure if they had manual ones after the late 1990s.
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘22 Toyota Sequoia V8
‘23 Lexus LS500 awd
‘95 Ford F-super duty 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles.
The Following User Says Thank You to 455Grandville For This Useful Post:
