Old 03-08-2021, 01:08 AM
rdl's Avatar
rdl rdl is offline
Question ‘69 RamAir Filter
I find that the replacement air filter from Ames is too tall. Anyone else? Is it the correct height? Is there a shorter version available?
'69 R/A III Firebird Convertible
14.0s @ 100.8mph AMA/OEM/OER
Old 03-10-2021, 03:14 PM
rdl's Avatar
rdl rdl is offline
Anyone?
Old 03-10-2021, 08:18 PM
69 Limelight 69 Limelight is offline
Default 69 GTO RamAir Filter
Wix 42102, AC-Delco A366C
Old 03-10-2021, 11:56 PM
rdl's Avatar
rdl rdl is offline
Question
I’m not clear on what this means. I know the original Delco part number, but I don’t believe they’re available. What is Wix 42102?
Old 03-11-2021, 12:00 AM
Is's the Wix Filter Brand part number you ask for at the auto parts store, or order from Rock Auto, etc. Same with the AC-Delco part number. I just prefer Wix brand.
Old 03-11-2021, 12:36 AM
rdl's Avatar
rdl rdl is offline
Thanks. The dimensions don’t seem right for that part number. The filter size needs to be 2” tall with a 10” diameter.
Old 03-11-2021, 01:15 AM
Uncle Judge's Avatar
Uncle Judge Uncle Judge is offline
Sorry. But the A366C is not even remotely close!
So the original AC part number is A367C or GM part number 6485167 for the original F body RA Hood Inlet upper pan filter. They are BIG $$$! An extremely close replacement is AC part number A117C or GM part number 5647255.
Take that to the bank!
Old 03-11-2021, 03:51 AM
Joe's Garage Joe's Garage is offline
Default The A366C / 6485167 / 42102 filter is the 1969-70 GTO / 1970-79 Trans Am size.
It fits the LOWER pan on 1969-70 GTOs with Ram Air and 1970-79 Trans Am with shaker.
The A367C / 6485167 fits into the UPPER pan on 1967-69 Firebirds with Ram Air.
Old 03-11-2021, 07:59 AM
hakansan's Avatar
hakansan hakansan is offline
What filter? FN144?
`70 GTO, 370 hp, 3:90, TH400.
Old 03-11-2021, 10:48 AM
OP didn't specify in 1st post that car was Ram Air F body. Guess I should have read his signature. I just assumed it was a GTO. My bad. Know nothing about F bodies. Ill back out and let you guys find OP the correct filter.
Old 03-11-2021, 10:56 AM
rdl's Avatar
rdl rdl is offline
Yes, FN144 — right diameter but too tall.
Old 03-15-2021, 01:32 PM
rdl's Avatar
rdl rdl is offline
hakansan... any other insights?
Old 03-16-2021, 04:45 PM
StevenK StevenK is offline
He is my spare still wrapped in sealed box with part #. Depth is 1.75 inch if that helps you.
Old 03-16-2021, 11:00 PM
rdl's Avatar
rdl rdl is offline
StevenK — Thank you, that’s what I needed to know. I now have a plan...
