69 Bird Gear Shift Bezel
The gear shift indicator bezel in my 69 is held in place by a large sheet metal screw through the top of the bezel into a corresponding hole in the front of the console. The rear of the bezel has no such screw or hole and is loose.
The part I’m describing is the metal piece that fits over the shifter arm and covers the large hole at top of console. What is the proper way at to attach the bezel to the console?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
There should be two screws that attach to the shifter using plastic nuts, similar to license plate fasteners. I can take some pics if you need it.
- Mike '69 Firebird 400 - Goldenrod Yellow, 455 +.060, '6s-7' heads, Comp Cam 276AH-10 (51-309-4), TH400, Ford 9-inch w/3.08, 800cfm Q-jet, Stock Intake, Hooker Headers, Flowmasters '68 Coronet 500 Convertible - Medium Gold Metallic, stock 318 +100,000 miles |
That’s not right...
'69 R/A III Firebird Convertible 14.0s @ 100.8mph AMA/OEM/OER |
That's not how those are attached by the factory.
Those certs are in clip receivers and the bezel literally pops into those clip receivers with riveted on clips, attached to the bezel. The repop ones are really crappy though. and it's not what I would call a great design. That'ss probably a reason your bezel is attached like that.
I've owned the car for 35 years, so I guess somebody else did that. I learned something new.
Mine has the top screw like in the pic Mike posted - very crude way to attach.
interesting thread with a suggested fix: https://firstgenfirebird.org/forums/...=244775&page=1
The original studs on the bottom of the bezel broke off easily and allowed the bezel to flop around.
There was a service update from Pontiac that instructed dealers to drill them out and put in screws.after stud failure.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
Thread Tools | |
Display Modes | |
