#41
#42
maybe for $1100 a set .... With free shipping
#43
The RPM CNC chamber E heads #61515 are $2400 everywhere I look. That seems to be what Speedmaster copied. I think $2200 gets you the old chambers. And the Speedmasters have gone up to $1,988. So they must be selling OK.
#44
I run my seats pretty narrow, Old school, the way Joe Mondello taught me. Intake even on a street engine, about .040" wide off the outside of the valve face about .020" Exhaust I move inward some, about .030-.040 off the outside edge. .050-.060" wide maximum. It does depend on the shape and thickness of the margin as you know. It just looked like those were way to the stem side of the face. The pic was kind of hard to see. I guess the current trend is to go a little wider now?
#45
The Following User Says Thank You to mgarblik For This Useful Post: | ||
#47
Do the Edelbrock exhaust bolt holes have helicoil inserts in them also? Can't tell from the picture....
#48
I agree, the speedmaster heads look solid out of the box, cleanup would help I would think. I am moving and would sell the new in box set that I have for $1599 shipped if anyone was wanting them today vs waiting for thanksgiving.
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
#49
Yes they have heli-coils.
#50
#51
Speedmasters have helicoils for rocker studs and exhaust manifolds.
NEW PROBLEM, though! I started to install the SM's on the motor I'm building. One head went on without issue. The other, however, I had several bolts that were "tight". I had chased and thoroughly cleaned the block's bolt holes, so new that was not the problem. The issue is the heads, some of the bolt holes are drilled a tad off-center. When I removed the head and looked into the bolt hole, you can see where the threads of the bolts were contacting the wall of the hole. At least the contact caused witness marks, so I know where to file. I'll try to post pictures later.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
#52
Quality control is what worries me today with parts. The last new intake I installed..the bolt holes were way off.
The Following User Says Thank You to ta man For This Useful Post: | ||
#53
I have found the majority of edelbrock intakes I've used (new) needed to have the intake flange milled. |
#54
Edlebrock..
Thread Tools | |
Display Modes | |
