Throw out bearing center force dual friction height
What height throw out bearing is everyone using with a center force dual friction clutch assembly with a stock Pontiac bell and clutch fork. Will be in a stock 66gto set up. Thanks.
when i did mine[70gto] it needed the long one. the number on the box was 1377c
Same here, long style. I'm using a Prw billet 11in. Flywheel . Stock pontiac bellhousing, clutch fork, Centerforce DF set up. Now the same exact setup, Except I had a stock Pontiac flywheel I had to use the short Throw out bearing. From just a flywheel change. Hope this helps.
I just used a McCleod long ball stud.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
