69 Firebird with Tilt Wheel Ignition Switch GM Part Number?
Can anyone advise the GM Part number for the 69 bird ignition switch WITH tilt wheel?
All I see available are compatible with GM 1990093 - which excludes Firebird
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
My Parts book says for 'All' ?
Interesting - A few eBay ads explicitly say GM 1990093 is not compatible with Firebird. Our host doesn't know the cross reference to the part number they sell either - only their internal part number.
This shouldn't be this difficult!!
Tilt is a very specific switch and bird only. A original GM switch is green in the pin connection area. I have a NOS in the original Delco carton, I can take pictures if you need for reference. I may have two NOS, can't remember.
Tim john--- |
Thanks - if you don't mind the picture of switch and carton w/numbers will help.
The 093 switch fits 1969 A and F body Pontiac’s and 1970 A body Pontiac ‘s. I’m not sure about the big cars. It’s easy to ID. at a glance because it’s cast in green plastic.
Here are several photos of a NOS ignition switch for a 69 Firebird with a "Tilt" steering column.
* Take notice of the "Green" colored insulated housing. Tim john--- Last edited by Tim john; 04-01-2021 at 08:02 AM. |
Additional 69 Firebird tilt column ignition switch photos.
I hope these photos are helpful. Tj- |
Instructions.
Tj- |
Excellent - thank you! I ordered a Borg Warner (CS-75) part that cross references with that part number - advertised as made in USA. Hopefully it works as intended.
Will, you have yours off and a pic of it?
Usually the tilt is opposite of the non-tilt. Like a mirror image of it.
I can get a pic and post it
Here is a pic with the old one (DelcoRemy) on left and Borg Warner CS-75 on right
Looking good!
