Old 04-05-2021, 09:46 PM
DM3 DM3 is offline
Default Coil Spring Question
I replaced my old springs with new stock height springs.* I made the mistake of purchasing them on ebay.* When I received the springs, they were just in a box, no paperwork etc.* Since the suspension seem soft, I really dont know if I got what I ordered.
The car has the following, tubular arms, QA-1 TN505 non-adjustable shocks, QA-1 sway bar, replacement Moog 5370 coil springs?? (ID - 3.63", Bar Dia. - 0.64", Spring Rate - 357, Load lbs. - 2022, Install Height - 10.25, Free Height - 15.94, # of coils - 9.81, OD - 4.91")* When* I searched the Moog site, these springs does even come up for firebird.* So they might not even be Moog springs.*
So I am looking to replace the springs again, but this time replace with a stiffer than stock coil spring.* Any suggestions?
IG: #67MoparBird (Follow my rebuild)
1967 Firebird 400
Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?'
Old 04-05-2021, 11:58 PM
455dan's Avatar
455dan 455dan is offline
Found this thread,
http://forums.maxperformanceinc.com/...d.php?t=840125
Like another poster in the thread, I have Guldstrand (G 11-001 springs) with about 2 3/4 inches of spring cut off,, but mine is a second gen. Not sure if these springs will fit in a 1st gen- but Formulas post 11 sure sounds like they will
Definitely not to soft.
