Old 04-06-2021, 03:38 PM
ta6point6's Avatar
Default What do use for sliding under vehicle, a creeper or a ?????
I like to use a old sleeping bag to throw under cars while working on them. My garage is not big enough for a lift. Well working on GMC Jimmy fuel pump it leaked gas all over the sleeping bag. I am trying to decide what to get next another sleeping bag or maybe a creeper. I have not used a creeper before but thought it might make it easier on my 50 year old body to get out from under the car. Anybody found anything better then a wheeled creeper or a thick blanket to lay down on the cold concrete?
I should just take it to a mechanic and let them change fuel pump but once they quote a price to repair,. The cheap miser in me comes out and I can not pay someone else to change out a 100 dollar part when I can do myself.
going bandit-Reynolds style
Old 04-06-2021, 03:40 PM
Stuart's Avatar
Stuart Stuart is offline
A big cardboard box flattened out. It's smooth enough to slide in and out, and when it gets dirty/oily I can toss it and find another big box that can be flattened out.
The Following 5 Users Say Thank You to Stuart For This Useful Post:
Old 04-06-2021, 03:53 PM
65CatCoupe 65CatCoupe is offline
I got it as a gift so I use a "magic creeper". Its kinda like a sleeping bag but it tracks with you. Eventually it transfers all of the garage floor dirt to your clothes but it does make it easier to get under and out.
Old 04-06-2021, 03:59 PM
rustedgoat rustedgoat is offline
Cardboard, takes up no space, easy to slide on, and free.
"Honestly the car will only be there for a few weeks, OK maybe a month at the most"
Old 04-06-2021, 04:04 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Yep. That`s what I use most times.
I do have a fancy Mac Tools creeper with the adjustable head rest. But, sometimes it lifts you too close to the bottom of the car with low jack stands.
Old 04-06-2021, 04:10 PM
Joe's Garage Joe's Garage is offline
Default It depends on what we're doing and how long we plan to be under there.
Cardboard works, but we found something that lasts longer.
We have a stack of about ten discarded 4'x8' coroplast (it's like corrogated plastic cardboard) political signs. They work well to keep you off the concrete, provide some insulation from the cold and keep the dirt off your clothes. You can also clean them off before or after a repair.
For something where we will be in and out a lot, a six-wheeled plastic creeper. Creepers are nice so long as you aren't doing a repair that requires torquing bolt or nuts - we've found that the creeper just turns YOU instead, so we don't use them too often. As mentioned, they can place you too close to the bottom of the car.
If we'll be there for a while, cleaning or troubleshooting or need to tighten things back up, the coroplast signs are a better deal. We also use a folded up bath towel as a headrest if we are there for long.
A quick in-and-out, like an oil change, we use a couple big dark-colored 'bath sheets' from COSTCO that have worn enough to retire them from household duty. You can lay them out quickly, get in there to loosen the drain plug and then get back out while things drain.
The bath sheets also work well when folded into a thicker cushion under our 'vintage' knees for brakes or tar removal or whatever.
Good luck!
Old 04-06-2021, 04:38 PM
Sirrotica's Avatar
I used to work on construction equipment, 99 times out of 100 on dirt. Two things I used to pickup at construction sites to lay on, were rolled rubber roofing, and foam insulation board.
Both worked well in lieu of a creeper on jobsites. The foam board was great for laying on the cold ground to keep you from laying directly on the ground in the winter. There is a little give to it also for cushioning. In the summer the rolled roofing was fine to keep you from lying on the dirt, and I just hosed it off and kept it in the truck.
On concrete I prefer a creeper with a metal frame, the plastic blow molded ones are practically worthless in my experiences.
I've always wanted to try one of those rigid plastic dog bone creepers, but I want to try one out before spending $150 on something that I don't know if it will work for me.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-06-2021, 04:43 PM
This.
Old 04-06-2021, 04:53 PM
sdbob sdbob is offline
I've used old rug, foam insulation, cardboard from new screen doors and I have 1/2" thick cardboard from hd delivery carton. I dont own a creeper. Working on grass ,dirt,stone just got use to cardboard.
Old 04-06-2021, 05:02 PM
DaleO's Avatar
DaleO DaleO is offline
Funny you should ask. : ). (I finally have some time finishing up new TH400 instal).
Old 04-06-2021, 05:06 PM
Verdoro 68's Avatar
Cardboard for me too.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 04-06-2021, 05:11 PM
Tom Vaught's Avatar
Boost Engineer
I have used all 3 of the ideas mentioned above. Cardboard, Blanket, Creeper.
What ever you do, make sure that you have some GOOD fabricated wheel stands for the
front and rear of the vehicle you are working on. B-Man has posted pictures of his "wooden Jack Stands" in the past. I use his design for the Wood Stands for the 4 tires and Commercial Steel Jack Stands as 'back-up stands under the frame.
Bit I am working on a concrete floor too, Not a dirt surface. The wood stand will work on dirt IF you put a flat wood bottom on the stands to add much more surface area to support the vehicle.
Tom V.
Old 04-06-2021, 05:30 PM
Region Warrior's Avatar
Used card board past 30 yrs ago. Creeper hard to keep from rolling around, even on card board.
Another plus toss it out if oil/dirt/atf gets on it.
Old 04-06-2021, 06:09 PM
Stuart's Avatar
That's a pretty good idea. They would be smoother than a piece of cardboard, plus they would resist water if the floor (or ground) is wet. I'll have to watch for one of those, although most neighborhood signs are smaller than that.
Old 04-06-2021, 06:51 PM
Elarson's Avatar
Elarson Elarson is offline
Go behind Lowe's BEFORE they open in the morning and they're usually unboxing refrigerators. If you wait til the store is open, the cardboard is already in the compactor.
FWIW,
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 04-06-2021, 07:27 PM
bill ryder's Avatar
bill ryder bill ryder is offline
X?? for cardboard. Used it for 50+ years. Nothing better than getting the car up 24 inches and sliding under on the cool concrete and just looking around. Not much work going on. Just cleaning and looking. I have taken a nap more than once. Still livin' in the 60s.
"Bill"!
The Following User Says Thank You to bill ryder For This Useful Post:
Old 04-06-2021, 09:28 PM
misterp266's Avatar
Recently I’ve been using a couple of kids sledding sheets. Flat plastic sheets with hand holes in one end. Cleanable, re usable, & slippery to move on. They are made to roll up but I leave them flat.
" Darksiders Rule "
Old 04-06-2021, 10:02 PM
Yup, cardboard for me, too.
To my wife's frustration, I refuse to put the traction enhancing sand in the epoxy garage floor paint, so that the cardboard can slide more easily
Old 04-06-2021, 10:03 PM
burd's Avatar
burd burd is offline
I use a thing called a mechanic. Lol
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
The Following User Says Thank You to burd For This Useful Post:
Old 04-06-2021, 10:11 PM
MUSLCAH MUSLCAH is offline
I use cardboard ...wrapped with the foam sheeting from various new car parts...like bumper cover wraps
