Closed Thread
Old 04-14-2021, 05:02 PM
Dragncar Dragncar is offline
Default Larger oil pump pickup
I am making my own pickup for my Steffs oil pan.
There is a issue others have talked about with say a Canton pickup. The dia is small, turns are tight and the pickup itself is a rectangle with hole to one far side.
Not good. people have reported oil pressure dipping on acceleration.
I talked to Mark Luhn about this and he told me things they did. I am doing something they used to do with my own twist to it. He said a lot of engines blow up because of this issue. And I can not have that !
I bought a slightly larger pickup (Ford I think) with a proper cone shaped pickup itself.
Tube is .814 vs .750 stock. Its no much larger but if you understand flow in a pipe you would know that a small increase in the size of the circle gives a much larger increase in flow.
So I bored the pump out for a slight press fit. Chopped the long pickup into sections I could put to use. And to solve my issue of two 90* corners needed I used a 1 3/4" long section of 1" pipe.
Thinking sort of like a 'fuel log" for a carb. You can make 90* turns if one pipe is much larger than the other so the liquid can make the turn without restriction.
I had to drill 2 13/16 holes in the 1" pipe. One for a short section of pickup tube to go the the pump. And the other for the cone shaped pickup itself.
I cut a slices out of a piece of 1 1/4" shaft to cap the 1" pipe for the last step of the process.
ID:	564718   Click image for larger version
ID:	564719   Click image for larger version
ID:	564720   Click image for larger version
Old 04-14-2021, 05:13 PM
Its a lot of messing around. Fitting, checking, mocking up.
My pan is 8 3/8 " deep on the inside. So I set the pickup level 8 1/4" off the pan rail. So once gasket is in there I have right at 3/8" clearance pan to pickup, perfect.
Will clean and get the caps welded on tonight. Then have to fabricate a strap from bolt hole in pump to pickup to make sure it can not fall off.
ID:	564722   Click image for larger version
ID:	564723   Click image for larger version
ID:	564724   Click image for larger version
ID:	564725   Click image for larger version
Old 04-14-2021, 05:57 PM
steve25 steve25 is offline
That looks great, but the main great thing about the stock pick up location is that since near the whole body of the pump is in the oil it does not have to make much suction at all to do the job of getting oil into itself.
It self primes on start up!
You look at some of the long pickup tubes on some Ford motors and it’s know wonder they knock as they do on cold starts!
In short I hope the level / amount of oil in your sump will height wise at least cover the top of the oil intake hole in the pump body?
This is also the reason why a small amount of positive pressure in the crankcase is not a bad thing in terms of forcing oil into the pump,
Old 04-14-2021, 06:07 PM
Tom Vaught's Avatar
Boost Engineer
You already have 14.7 psi of atmospheric pressure (at sea level) pushing on the oil in the crankcase to enter the oil pump.
Positive pressure in the oil pan above that 14.7 psi suggests that you have a lousy sealing ring package installed on your pistons.
Tom V.
Old 04-14-2021, 11:48 PM
Originally Posted by Scott Roberts View Post
Good idea but total fail on execution...
Execution ? Its not done yet. Look at the 4th pic. See the weld below the cone ? That tube is .065 thick. It was welded with a great big machine with .045 DS 7100 wire.
Most people would not have even tried it. Its butt welded and enough volts were used that most would burn right through it. I do things with a torch and stinger most would never even try.
I could have turned to volts down to make a pretty weld for knownothings like you but I did what was best and strongest.
That weld breaks and the engine blows up.
I have a 170 amp 220V welder with .023 wire I could have used. But was tacked together at work.
I have forgotten more about welding than you have ever known.
i started this thread to let others know what they can do and to get input from the smart, accomplished people. Not you.
Why should I listen to someone who does not even build their own engines ?
Old 04-14-2021, 11:51 PM
Tom V.
Tom, am I right about the 2 tubes and the 90* turn. One being much larger so there is no restriction ? The whole pickup should be in oil. I will post up some pics with the pump and pickup all together when I am done.
Thanks.
Old 04-15-2021, 06:20 AM
This is the best possible form/ area change for getting fluid or air around a bend in the least possible run length!
It can provide nearly twice the flow area even around a 180 degree bend, no less 90 degree!
I have a patient pending on this form so think twice!
ID:	564748   Click image for larger version
ID:	564749   Click image for larger version
ID:	564750   Click image for larger version
Old 04-15-2021, 07:59 AM
ErikW's Avatar
ErikW ErikW is offline
This is what you need. They can sell you one with the pickup not welded and you set pickup height then weld.
http://www.luhnperformance.com/pontiac.html
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 04-15-2021, 08:13 AM
slowbird's Avatar
slowbird slowbird is offline
By increasing the feed size have you really increased much on the output side? The gear size in the pump dictates the volume moved per revolution does it not?
What exactly is being accomplished by increasing the feed size? Is the normal/stock size restrictive to the pump?
Old 04-15-2021, 08:27 AM
ErikW's Avatar
Call Luhn and they'll explain it to you
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 04-15-2021, 08:36 AM
A too small pickup tube would cavitate (adding air instead of oil).
Probably happen at a higher RPM.
Old 04-15-2021, 08:59 AM
slowbird's Avatar
I can see that but do we think that's currently an issue? I spun my Mellings with stock sized pickup to 8200rpm without oiling issues. That was with 13-14" of vacuum in crank case so no 14.7psi of atmosphere helping to push oil into pump.
Old 04-15-2021, 10:23 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
It may not be an issue, but a larger dia inlet cant hurt anything either.
Old 04-15-2021, 10:30 AM
slowbird's Avatar
I totally agree if you're able to do the mods youself. Otherwise one needs to weigh the benefits vs the added cost of buy a pump with the in large inlet.
Alot of stuff has no downside to doing it but it does add cost to the build while providing very little upside. It's very easy to go way beyond the budget when building engines. And since this is the street section, im assuming most of the builds here are budget minded lower hp lower rpm builds.
Old 04-15-2021, 10:59 AM
Tom Vaught's Avatar
Boost Engineer
Thanks.
The restriction is now the short "stub" you have going into the oil pump.
The restriction, size of the pipe there is not as important as what you did with the inlet into that short "stub". If that short "stub" has a sharp edge on it anywhere vs the smooth stock oil pick-up tube, then the flow drops a bunch.
Sometimes in some flow applications (with air for example) as much as 40% less flow. I would have made that specific piece a very smooth radiused inlet BEFORE I stuck it into the larger common pipe you are using to make the "Turn" into the pump. Radius BEFORE WELD.
Tom V.
Old 04-15-2021, 03:37 PM
For reference, this is how i did mine, using the same pick up tube to start with, thank you Dragncar for the part number on the tube. I brazed the pick up screen back to the tubing instead of trying to weld it because of my skill set..lol...
Old 04-15-2021, 04:49 PM
That looks like some of the joints I have seen on some industrial fire sprinkler systems. They are cast and bolt onto the pipes with rubber rings and receiver groves in the pipe.
its been engineered right !
Old 04-15-2021, 04:50 PM
I would think that the use of a larger diameter manifold type tube like you used should provide the flow needed.
Old 04-15-2021, 04:53 PM
All the indications show the stock size tube is a little small under some conditions. Luhn's oil pump dyno setup have proved it. Its one the stab of the throttle from say 2000 RPM to redline it takes a split second for the pressure to catch up.
Thats what I am trying to avoid.
Old 04-15-2021, 04:57 PM
I thought about that but did not think I could get the cone part separated from the tube without damaging the screen.
That tab on the pickup in stock form where it bots to the pump, I could not get it off with heat. I had to cut it in half.
But actually what you did was simpler and you do not have to deal with the 90s. One long smooth tube.
Closed Thread
