When you get to the track. If you can get a 2.25 60 foot time out of it, I see it running a 8.3x at around 93 MPH.
Stan
It was dynoed with 1.75 headers and ram air manifolds and 2,5 mandrel headpipes. The dyno sheet here was with headers and the cast manifolds lost like 16 hp. Yes that what it did in the 1/8th a few years ago. Im using the RA manifolds on the car now.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' Last edited by scott70; 04-15-2021 at 03:47 PM. |
I would love to see 93 mph,,,,I would be really surprised to gain 6mph from prior to now. I really have to baby it out of the hole with the street tires and the gearing isnt great for taking off. Back in around 2000 I temporarily through in a different iron headed 455 with about the same cam in my gto but with headers and and auto trans and ran 7.4 at 93.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' Last edited by scott70; 04-15-2021 at 04:07 PM. |
X10 great iron head street build. You need drag radials or slicks at the track or launching will be crazy inconsistent
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
On shift points I was hoping a highly experienced 4 speed drag racer would chime in for absolute clarity from experience to get best ET. because it's not so much the RPM at which you shift at it's also where your at in the torque curve in the next new gear based on RPM drop,
I suspect you want to be at peak torque just after grabbing a new gear but I have never science that out on the track The RPM drop can be figured out mathematically |
This is a great combo.
Where did the timing end up? |
I believe we tried 30,32 and 34 and 32 total was the best.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
Wow... thats one FLAT torque curve!!! Very impressive...
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" |
The question is what is peak torque and at what RPM? As you can see from a graph of the dyno sheet torque is past its peak when the sheet starts.
Stan
Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
Actually playing back the video in slow motion of the dyno pull and looking at some other dyno pull sheets that were started at 3000 rpms,, peak trq looks like 3100 to 3200 rpms and then takes a couple of ft lb dip and almost recovers to peak trq at 3600 and then slowly drops from there.
The Following User Says Thank You to scott70 For This Useful Post: | ||
Checking with motor warmed up,,my lisle cylinder pressure gauge is showing 177 psi. Don't know how accurate gauge is though.
Thanks for sharing your combo, jealous here. Would you mind sharing the fuel system?
With 455 ci with 9.7:1 and a 288 degree intake lobe in @ 108 ICL. That is just what I would want to see for cranking compression psi. Stan
That's excellent. I've had 100% success with pump gas and cranking compressions in that range. Usually when I have an engine up in the 190-195 range they start getting really finicky on pump gas, especially in the summer time and warmer engine temps.
Good to hear the 177 is about where it should be ! I compared the gauge to the gauge on my air compressor at 120 psi and there was only 2 psi difference so I guess the gauge is accurate.
My fuel system isnt much,,stock 3/8 line , fuel tank and a mechanical carter fuel pump thats been there since the 90's.Years ago with a temporary iron headed 455 and auto trans transplanted it did 11.7 at 115 mph in full street trim with the same fuel system ,,weighing in at 3950 with me in it.. I was probably pushing the limits of that fuel setup.
Looks like another 11 second "truck motor" that really needs aluminum heads to perform.
I plan to somewhat replicate what you have done so well on a 455 so thanks for posting this information. Mantra around here is using Pontiac iron d-port heads have held the community back but I see it as not true for a street car. Race is a different story but a efficient port 455 on the street does not seem like a bad idea at all. Has your block been zero decked? |
#39
When I had the motor freshened I ordered some pistons from Paul K that had a custom CH of 1.50. The pistons that were in it had a 1.47 CH and were around .035 in the hole. So now I'm around .005 in the hole so close to zero deck and didn't cut the block. Figured while in there I'd tighten up the quench...with prior head gasket thickness it was about 063 and now is around 041.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' Last edited by scott70; 04-24-2021 at 11:11 AM. |
#40
If that was a little lean on the upper rpms could I try a little richer secondary rod?It's a 7040267. I'm not sure at the moment what they are but I see it has a G hanger. Probably the only way to see would be to take it to the track to compare numbers,,,should of tried it when it was on the dyno.
Yeah,,a thread I started over a year ago.
