#61
Whats wrong with using both type of fans? Mechanical AND electric. I use a stock GM mechanical fan with clutch and shroud, and a slimline electric helper fan hidden inside the shroud. Best of both worlds.
Sent from my SM-T817V using Tapatalk |
#63
I see benefit to the electric at idle. My electric setup could cool just fine at idle under the worst conditions. My clutch setup works great in all AZ weather except extended idle with ac running, in 115* summer weather. You know, stuck in a drive thru for 15 minutes. But in the wintertime when Temps are 70's I don't even sweat that.
I'd be OK with a dual as long as the electric unit didn't present an impediment to air flow at cruise. I learned to alter my driving habits, tho. If the drive thru line is long, I just go inside to enjoy somebody else's icy air conditioning.
#64
Just kidding. I couldn't resist because when you were helping me with cooling system suggestions you gave the same drive-thru benchmark test of the cooling system. Oh, and I second the concern about the electric impeding air flow to the mechanical fan on a dual setup.
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE |
#65
#66
UPDATE
I finally got my car back on the road after the transmission fiasco. (See other thread) I installed a repop factory shroud, 18", 6 blade Derale fan, an extreme duty fan clutch, & a 160* T-stat during the down time. The temps still creep up to as high as 215*-220* in town with the AC on, but once I can get up to highway speeds (and RPMs), the temp comes back down to 165*-175*! The faster I go, the cooler it gets, but it sounds like a Cessna 150 going down the road. Still needs help at idle or around town, but at least it's getting better.
No! Do not try! Do! Or do not. There is no try. - Yoda 1967 Firebird Restoration 2005 - 1/25/2017 |
#68
Pics? That might also help us spot something that can improve air flow.
--------------------------- Fool Around, Get Hurt, Don't come Crying to me. |
#69
I ended up with the Cold Case radiator since it gave the best overall performance for my setup.
Heres a link to my review of three different radiators I've tried in my car. I need to find a fan clutch with a shorter shaft. The one I have pushes the fan a little too far inside the shroud. My total cooling capacity is only about 2.5 gallons so I'm kicking around the idea of fabricating a container to fit in the open space in the front left fender and plumbing it into the inlet side of the radiator. I think I can get another 2+ gallons of capacity in the system if it works.
#70
Are you set up for the Fitech to control the timing? That might be the last thing you need to adjust, if not.
I have heard good things about the Fitech controlling the timing. It might add a bunch of timing while your at idle with a zero TPS reading and temps creeping up.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
#71
I increased my capacity by roughly 1-1 1/2 gallons so your 2 gallons should be plenty. Taking a lit cigarette and usong the smoke trail to trace the air pattern is also an aid to find out if the air is flowing fast enough and in the right places, that he also showed me. The old timers always have some secrets because they've been there and done that before. |
#72
http://www.machdevelopment.com/album...775/527566.htm |
#73
X2.
#74
I did a little measuring in the unused area between the driver side fender & radiator and I have room for, up to, a 10"H X 12"L X 7"W tank which would give me an extra 3.5 gallon capacity. I'm thinking that I could plumb the system to come out of the thermostat housing, go into the tank, then out of the tank, and go into the radiator inlet. Can anyone think of a reason why this wouldn't work?
#75
In your basic A or F body, my radiator guy at the time, suggest a tin gas can with nipples soldered in both ends, one in the filler neck and one in the bottom. The can would be spliced into the upper radiator hose. Of course it would need to be properly secured under the hood. I was going to do just that when I decided with all the extra room in front of the car I would instead use 2 radiators. I placed them with both front sides facing each other so the necks on the front radiator faced forward, and the rear radiator faced in it's normal direction, yes the plumbing was ugly....LOL The path of the water was, out of the thermostat housing into the upper front radiator, out of the bottom of the front radiator into the top of the rear radiator then out of the bottom of the rear radiator back to the timing cover. It took awhile to get it plumbed with hoses and small diameter exhaust pipe. I was rewarded with a Pontiac that never got above 180, no matter how long the race was, how long it idled, or how hot the ambient air temp was. I had a double pass cooling system before there were double pass cooling systems....... Pontiacs on an oval track are really tough to keep cool with the standard cooling system, been there and done it enough times to know that you really need more than the engineers designed into the OEM system. In another 455 Firebird race car we used 2 radiators soldered together because there was no room to have the hoses coming out of the front of the forward radiator. The radiators were stacked and the front radiator nipples were soldered into the tanks of the rear radiator, in effect making a 6 core radiator (2, 3 cores soldered together). The thing is the fan has a problem pulling air through all those fins and tubes (the reason that there are never more than 4 core radiators in cars). In effect we probably hurt the heat transfer from radiator to air by exceeding the 4 core limit, but we more than gained what we lost by the added capacity of coolant. Nether one of these cars ever ran hot after addition of the extra radiator. One other experiment was in a demo derby 71 Bonneville, 400. We put a 15 gallon barrel under the package shelf with connections on it to plumb it into the heater circuit. Pontiacs used for demo derby usually O/H in short order because when abused they seem to need a lot of cooling, and if the radiator starts leaking the time it takes them to O/H and shut down is usually fairly short. With 15 gallons of extra water that would buy some time before the engine heat got critical. This was kind of a failed experiment however because the car got knocked out long before the engine ever got hot. But having that extra 15 gallons we felt we could have run it with no radiator at all for quite awhile. So that is the ways I've added coolant capacity to race/demo cars and none of those 3 engines even hinted of getting warm after adding coolant capacity. HD trucks have coolant tanks for upping the capacity of the coolant routinely, hauling 80,000 Lbs over mountains, they need the extra coolant capacity. Problem is in a car you usually don't have a bunch of room under the hood to add a tank. In a Pontiac I would be looking at the rectangular can I described earlier inline in the upper radiator hose, or possibly a tank inline in the heater circuit. Now I really don't have enough data from the demo car to know if the reduced hose size down to heater hose would offer enough flow to impact the coolant temps on a Pontiac or not. This would be an area someone would need to build the system into the heater circuit to see if there was enough flow to work. I feel that the heater circuit may just be the little extra some Pontiacs need to have enough, just my opinion..... Adding the tank into the heater circuit opens up being able to mount it other than under the hood. If you mount it further away you'll also gain more capacity in the plumbing needed to have it remote mounted. I think most people that have been around Pontiacs for any length of time know that the OEM type system has to be spot on for it to hold up to any racing or hard use. Any deficiency will show up quickly. I believe that when designed originally Pontiac engineers had a small percentage of reserve cooling and as soon as any component wasn't operating at 100% there went the reserve cooling. To put it simply, it was right on the edge when new, after some aging we have problems. Add to that someone trying to use a OEM style system to cool a 505 CI engine, your going to run into problems. Time to think outside the OEM box.......... There you have it, my experiments into cooling a dirt track/demo derby Pontiacs. If someone can transfer some of these experiments and success's over to their own cars, that's great, glad I could help out. |
#76
Good info Sirrotica. I was toying with the idea of using my 69 Lemans parts car as a dirt track car for fun.
#77
I hate for you to have to do all that extra work to solve what is now only a stop and go cooling issue.
#78
I have the AT radiator, but I'm using a separate tranny cooler so all of the tests would be the same.
#79
#80
Any way you can show a picture of the fan/shroud setup?
