Old 06-04-2021, 05:53 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Default solid roller cam selection
I am in the process of building a 463 stroker. Main components are Scat forged crank with 4.25 stroke, Icon forged pistons 4.165 and Eagle 6.8 forged rods. Will be using a Northwind intake port matched to KRE 325 cfm heads. This engine will be going into my 79 Trans Am which is at 3600 race weight. Rear gear is 3.73 and I will stay with my 350 tranny and I run MT 275/60 x15 drag radials. The cam that Bullet recommends is 262/271 at .050 with lift at .680/.688 and LSA at 108 + 4. I want to keep the shift points at or below 6500 and this will be a street/strip car so I am willing to give up a little peak power to have slightly better idle quality. Thinking maybe a 110 or 112 LSA might give me a balance of what I am looking for. What do you guys think?
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
Old 06-04-2021, 06:43 PM
Scott65's Avatar
Scott65 Scott65 is offline
If idle is important, I'd agree with the 110 or 112 lsa. Who at Bullet did you speak with? I understand Tim is the one that speaks Pontiac fluently.
Old 06-04-2021, 07:00 PM
pastry_chef's Avatar
By chance do you have a flow sheet?
Old 06-04-2021, 07:22 PM
Chuck is the only one I have talked to at Bullet, and yea I was thinking 112 would be my choice. Next week I will try to contact Tim if he is the guy most familiar with Pontiacs. The heads are on order so I don't have a flow sheet at this point.
Old 06-04-2021, 07:43 PM
Agree, I have been dealing and talking with Tim about Pontiac Camshafts for many years.
He just did a special camshaft profile for a friend of mine.
Old 06-04-2021, 08:04 PM
Tom, thanks for the confirmation.
Old 06-04-2021, 08:40 PM
Richie Hoffman's Avatar
Talk to Tim at Bullet
2008KRE Q16 Winner
Old 06-04-2021, 11:39 PM
Jay S's Avatar
Jay S Jay S is offline
Their cam pick is only as good as the info you share with them. If you think the cam might have a little to radical of an idle I would mention that. Moving the LSA 262/270 cam out to 110 or 112 with that much head is likely going to send the rpms more than what it sounds like you are hoping for.
I have always talked to Tim also. I would have thought if your not trying to rev the engine out with that much head for street and strip they would have used closer to a single pattern cam or at least a smaller split. Then they can keep the LSA in tighter, have adequate overlap and let the upper rpm nose over a little sooner with the smaller exhaust profile. I am not sure which profile was picked, but for street and strip Tim ground the .4176 profiles for us, but they have another similar profile with more with more lift that isn’t to bad on the street either if you are using 1.5s. Both seem to be a little gentler valve terrain parts and not require a bunch of spring pressure.
Old 06-05-2021, 09:36 AM
Yea, as the old saying goes I am probably trying to have my cake and eat it too. Need to keep the rpms reasonable so the basic 2-bolt main block will live a long healthy life. But at the same time wanting to get the most I can out of the combo. As to the cam profile, the lift #s are based on 1.65 rockers which would indicate a .4121/.4170 lobe lift. Hopefully I can talk to Tim at Bullet next week and get his input.
Old 06-05-2021, 03:12 PM
Yup.
Here is a bit more that "Google" blessed me with. lol.
Assuming 325 CFM intake / 230 CFM exhaust.
The Bullet suggestion is pretty solid. Personally I'd go no wider than 110 LSA.
Old 06-08-2021, 08:32 AM
grandville455's Avatar
I think Greg Weigart is pretty happy with his solid roller i believe in the rpm range your looking for too
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 06-08-2021, 10:28 AM
Bill Eveland's Avatar
Sounds close to the cam i have, you should be good with rpm range with that duration.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 06-08-2021, 10:42 AM
Bill, thanks for your input. What are your shift points? And what race weight?
Old 06-08-2021, 12:08 PM
I bought that for my 469 High Port combo, 3400 lbs and 6500 rpm. I never ran it, last year I had a 273/277 and went 6.40s
6.27@107
9.97@131
Old 06-08-2021, 01:50 PM
firechickenman's Avatar
firechickenman firechickenman is offline
Yes, very happy with it for my combo which is very close to prostreet64's combo he's building. Comp XE Street Roller lobes - 266/272 duration on a 110 LSA installed at 106 ICL. Idles at about 900 in gear, runs best when shifted at 6500 and crosses the line at 6500-6600 with my 3.73's and a 275/60R15 at 133-135 mph.
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 06-08-2021, 03:54 PM
AG's Avatar
AG AG is offline
My race cam is a little smaller at 262/266 at 0.050" with best shift points at 6500 going through the traps at 6700 and uses a 110 LSA with a 106 ICL. Intake is a street lobe and the other is a base design I think, works well.
Old 06-08-2021, 04:04 PM
Greg, what is the lift for that cam? and what is your race weight? Thanks.
Old 06-08-2021, 04:06 PM
AG, are the lift #s with 1.5 rockers?
Old 06-08-2021, 09:59 PM
AG's Avatar
AG AG is offline
Lobe lift is 0.392"/0.399"
