Old 08-29-2021, 08:38 AM
garysone garysone is offline
Default clutch problems
trying to awake my barn find 69 judge ( my barn for 30 plus years ) put a new clutch , pressure plate , throw out bearing kit from summit in it but don.t have enough pedal travel to release it. Are there different length throw out bearings like chevy used to use other wise the clutch fork might be the problem . it actually hits the bellhousing. thanks
Old 08-29-2021, 09:15 AM
4dblnkldude's Avatar
You may need a longer ball stud. Is this a stock set-up?
Old 08-29-2021, 12:27 PM
ID67goat's Avatar
ID67goat ID67goat is online now
Yes there are different length throwout bearings. All the Pontiac ones I have seen are taller. Do you still have the old parts to compare them?
Adlustable ball stud could be used as mentioned to help compensate for the shorter TB but it would be best to just get the correct throw out bearing.
Old 08-29-2021, 07:55 PM
the motor and trans was in it but not running wasn't a gto motor but still had the 3 speed top loader trans
Old 09-05-2021, 04:09 PM
3 and 4 speed used identical clutch and linkage. I concur that sounds like you need the thicker throw out bearing
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
