1968 gto, lemans duct,dash,carb, rear
I need a defrost duct, 7028268 carb,dash pad , and a 2.93 rear for a 1968 gto. Thanks brian
Hi
I should have the duct
will check tomorrow my 268 is a 69 may have a 293 also a core non ac pad Scott |
Ive got a 2.93 ring a pinion set with an open carrier.
I have the duct and I nice dash pad with 1 slight crack in it. Good for a driver..I'm in pa
The Following User Says Thank You to Ram4king For This Useful Post: | ||
i've got a 68 rear that I believe is a 2:93 open
74 GTO 406 T400 74 Firebird 350 4-speed 68 GTO Convertible 400 T400 76 GP LJ 400 4BBL T400 78 Chevy 1/2 Ton Truck Oh yea I love my wife very much For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm |
I have a 7028268 carb in storage but not sure of its condition, date code or if complete. I'll check it out some time this week if you're still interested. Email me please.
Robert 6d7gto@gmail.com |
if you could check it out that would be great. let me know how much etc . shape
is it the complete rear ? how much are u asking for it and what kind of condition ? thanks Brian
How much do you want for the duct and dash and are the 4 tabs on the duct ok and how is the condition ? thanks Brian
how much for the duct? the pad I need is A/c pad i should have said that sorry.
Hi
Brian
Pics Scott thanks for the chat couldnt get the other email to work so I posted here.. ring me if interested thanks |
I have a black AC dash pad. Pretty nice shape. I also have a 2.93 with open carrier—cheap.
Will go to the storeroom tomorrow and try to post my findings tomorrow evening.
HO Qjet: 7028268 WF dated 0228 on base plate
Good news is that a helicoil has already been professionally installed in the fuel inlet. You can tell a pro machine shop did the work because they resurfaced the mating surface where the inlet nut/gasket seats for a leak proof installation. The base plate has been bead blasted with new primary bushings installed. This wasn't the original base plate but is of the correct casting (7035733). I robbed Peter to pay Paul so the original is long gone. I had prepared this one for another '68 carb that wasn't a good date match for the customer. The nice thing about carbs not dated on the main bowl is you can simply swap base plates for a more suitable date code match. I have one more 7035733 dated 0828. Used to have a bunch of 'em but slowly depleted my stash. Many of the steel parts have already been replated so this won't take much to make for a concours restoration. Sale will include a repro choke pull off. Or if you prefer, I can rebuild an original pull off (with new guts) for a small extra charge. Most folks don't really care, but it does give it that nice extra touch for those of us into the numbers matching hobby. Carb will need the usual: new metering jets, primary metering rods, needle/seat, etc. and of a course a gasket kit. Otherwise this 7028268 will be complete and numbers matching. I can have the bowl and air horn castings dichromated (correctly colored) at my local carb shop who uses the same formulation as GM did 45 years ago. My cost is about $100 if you want that service done. Takes about two to three weeks. I figure the carb in its current form is worth $250 un-restored. I'm asking $200. One year guarantee. |
can u post or email me pictures of the dash --- and the rear --- does it have a stamp on it WD or something? what year car is it out of ? thanks Brian
68 PARTS
I HAVE THE REAR I AM PARTING A 68
The rear I have is out of a 68 lemans. I can check for codes. |
