'72 Hurst linkage rods and levers 5615 5617 5621 and up rod 5624
Hi, I need a few select parts to fill out my Hurst linkage for a '72 Trans Am:
Need 2 -5615 levers Need 1 - 5617 rod with attachment pin Need 1 - 5621 rod with attachment pin Also need the up rod from the frame mounted swivel to the steering shaft. I think it's part no. is stamped 5624 Thank you. Greg gregsm@earthlink.net 210-326-6503
http://www.starspangledbannerchallenge.com/ |
They are part stamped? I cleaned a set I had and didn't find a part stamp, and lever had some stuff on it with no part # I could see with my eyes. Where is it on rod pieces? Different from A body, and year to year different too? Just asking..
Mike/Illinois |
Upper back drive rod "5624" is stamped in very small numbers & is '70-74 F 4spd Muncie application.
The 5615 levers, & believe, their mating thick shift rods are same between A-Body & F-body for '71-74 Muncie 4 speeds. Will go through my shifter tubs & see if any extra levers or shift rods. Am afraid, most the extra is is going to be from later BW 2nd design T10's.
The numbers are stamped on the rods and levers themselves. I know the levers are incorrectly set facing down instead of facing up, but in these pics you can see the numbers.
'ol Pinion head is correct, the shifter levers and rods are for '70~'74. I wouldn't think the 'up' rod would be the same on F body and A body, but I'm not sure. I just know the 5624 is for F body. Thanks for looking for these.
Thanks for the education, as the rods I have are not stamped for sure. Even with my bad eyes..
Mike/Illinois |
ttt
If your still looking for the above pieces, I have all of those...
I get $250.00 shipped to Texas crash_enterprises@yahoo.com Thanks... Crash |
ttt
I got all my parts sourced.
Thank you PY and thank you Crash!
