Old 11-07-2013, 12:06 PM
Old Goat Racer's Avatar
Default L2423 Pistons
I bought an SR 455 short block years ago. Someone put an SD 495030 crank, SD rods & these pistons in it. Looking for info on the pistons.
Everybody knows somthin.
Nobody knows everything !
Old 11-07-2013, 01:34 PM
I believe they fit only the SD rod. (narrow pin boss for SD rod)
Have single valve relief, correct?
(not 2 like normal pistons.)
These aren't the pop up pistons right?
(didn't look them up, from memory, but crs possible)
Old 12-08-2013, 12:10 PM
Thinking about putting the short block together & dropping a set of Edelbrocks on top.
Old 12-08-2013, 12:23 PM
Richie Hoffman's Avatar
Used that combo for years single valve relief piston ra 4 heads flat tappet hyd cam in a 3100 lb car I went 10.00 9.90 in the early 1990,s
2008KRE Q16 Winner
The Following User Says Thank You to Richie Hoffman For This Useful Post:
Old 12-08-2013, 01:16 PM
PONTYRAT1 PONTYRAT1 is offline
Default PISTONS
Have those in my 455 motor E-heads and Eagle rods floating pins No issues
The Following User Says Thank You to PONTYRAT1 For This Useful Post:
Old 12-08-2013, 05:01 PM
GOSFAST GOSFAST is offline
Default Piston I.D.
Those are flat-top pieces with a single "trough" valve pocket (mentioned above), 3 cc's, 1.497 C.H., and weigh (nominally) 575 grams.
Has somewhat "heavy" ring pack, 1/16", 5/64", and 3/16".
Recommended P/W .005".
Thanks, Gary in N.Y.
P.S. My records show "press-fit" only, no provision for lock ring grooves. This might be different on later pieces, not sure. Also not sure about centered or offset wrist pins??
The Following User Says Thank You to GOSFAST For This Useful Post:
