Old 11-27-2013, 11:05 AM
pressgod1's Avatar
pressgod1 pressgod1 is offline
Default headlights
took my car out last night and never drive at night...headlights were dull as dull can get. They are original T3 can I buy new replacements(modern technology) lamps and just install?
1969 Custom"S" 400 stroked to 455 Holley Dominator 870 Pontiac Performer intake KRE heads Kieth Black pistons Crane Cam Hooker ceramic coated headers CVF Racing pulley system 700r4 trans built/700hp Ford 9" 3.73 posi 4-wheel disc brakes
Old 11-27-2013, 11:21 AM
pfilean's Avatar
pfilean pfilean is offline
Clean up the connections especially the grounds. The bulb will lose very little light power with age. But the ground connections are usually the problem.
Old 11-27-2013, 11:35 AM
David Jones's Avatar
I put halogens in mine about 10 years ago. That made quite the difference........
Old 11-27-2013, 11:40 AM
abefromen's Avatar
abefromen abefromen is offline
http://www.madelectrical.com/electri...adlights.shtml
The Following User Says Thank You to abefromen For This Useful Post:
Old 11-27-2013, 11:46 AM
ELKHORNAOG7 ELKHORNAOG7 is offline
Talking
Yes you can I got them for my 68 firebird the 5 3/4" it's just the lens and you buy the new bulbs for them at any parts store, Just don't know where for sure I got them, but I know it was online I think it was on ebay and they were not that much money, and you will see a big change at night night, I want to hook up some relays for the hi & low beams just did not get around to it yet because I'm not drawing a lot of of current from my car just the ign. system but if you are using a lot of current thru your car and you make the switch to these lights you may want to also hook up some relays for them it takes the load off your head light switch and your lights won't dull when when you apply more load on your elec.system---BOB
Old 11-27-2013, 01:19 PM
Schurkey Schurkey is offline
Strongly suggest adding relays for headlight operation. I pull power directly from alternator terminal, via fusable link. Verify voltage drop is acceptable on both the power and ground side of the power supply.
Drop-in halogen replacement sealed-beams are readily available and fairly inexpensive.
Old 11-29-2013, 08:45 AM
jetdoc jetdoc is offline
I bought Sylvania halogens sealed beams and through they were bright. Last night I installed 35 watt HID's 4500K and love them, best thing is the housings were glass. I paid like $65.00 to do the low beams. Mark
Old 11-29-2013, 09:11 AM
chrisp chrisp is offline
What alt. / regulator are you using ?
Old 11-29-2013, 09:32 AM
pressgod1's Avatar
Default alternator
single wire internal regulator 100amp...wiring harness from Madelectric works like a charm. Looking at their web site will invest in the harness for the headlights as well. Halogens will be installed but will see how the originals work first with the new harness.
Old 11-29-2013, 12:23 PM
Old Goat 67's Avatar
Food for thought here.
I did the relay mod a couple of years ago, but as a before & after process, I measured the current flow on the B+ lead going to the headlamp switch.
It showed 11.8 amps on high beam before the addition of the relays and 0.1 amp current after.
Point of study is that a 45+ year old switch will work & last MUCH longer with reduced current and therefore reduced heat being generated in it's contacts!
Even the Halogen lights showed better light output also.
Charles
Thread Tools
Display Modes
