Old 10-24-2024, 03:34 AM
Kenth's Avatar
Kenth Kenth is offline
What throws a lot of people is that while Pontiac ran a resistor wire under the dash, Chevy ran it right off the starter solenoid. Why they did it differently I have no idea.
The resistor wire is used in "Run" position to save the points, even in a Chevy.
I think you are reffering to the "Start" wire which indeed, in some applications, also Pontiac, is connected to the "R" (Remote NOT Resistor) terminal on the starter solenoid.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-24-2024, 11:52 PM
That’s what I meant to say but you did so much clearer and correctly.
1969 Cat (3 Cvt’s & 2dr ht)
1969 Bonnie Cvt & 2 wagons
Old 10-25-2024, 12:04 AM
Btw. Talking electric bugs here is a quiz about what happened to me tonight in my 69 Executive sedan. I was driving it after dark tonight from my storage garage to my home garage (getting cars where I want them pre winter lockdown) and on the way I noticed the right turn indicator on the dash wasn’t working. I listened carefully and I could sort of hear the flasher but couldn’t tell for sure if the front flasher was working.
I got home and in the driveway I put on the right flasher and saw the rear light was flashing but not the front and not the indicator on the dash. So I put the left flasher on, indicator worked as did the front light but not the rear. I then shut off the flasher and instead put on the 4 way and the exact same lights flashed (right rear, left front and left dash indicator) while the rest failed to light or flash. Last clue, headlights off or on made no difference and all other lights (park, tail, side marker, headlights etc work perfect).
I figured it out after a while. Some background, this is a low mile, untouched survivor that has never had any monkeying under the dash or any socket corrosion etc.
It is a 1969 Executive 4door sedan with AC and automatic etc.
Any guesses?
Old 10-25-2024, 11:18 AM
AG's Avatar
AG AG is offline
Grounding issue?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 10-25-2024, 02:32 PM
It was actually something stupid. The dash harness connector that clips on to the turn signal harness on the steering column was not properly clicked into place but looked like it was. One side was in just deep enough to make contact but the other end wasn’t quite making contact on a few wires.
I was glad to figure it out because I was moving the car to winter storage and while it wore a legitimately registered plate and valid insurance they might have been possibly for another car. So a traffic stop wouldn’t have been desirable.
Thread Tools
Display Modes
