4.88 gear!
So my car is in the shop having some things done, including the gear change. My guy calls me today and says it has 4.88 gears in it. He counted the teeth 3 times to be sure. That was a surprise. I thought it was probably a 4.11. Based on that I won't do the 3.08. Probably 3.31 vs 3.55. Now I need a new carrier too.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
My 70 Judge had a M20 and 3.55 gear and I thought it was a good compromise between acceleration and freeway cruising
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
Not sure a 3.31 is available anymore. 3.42 is pretty popular.
Make SURE they Shim the front pinion seal OUT away from the carrier by 1/8" . Use a rod, or thick wire or make a giant 1/8 "washer. If they don't, it will leak. The seals now available are Not for this type of shorter nose housing. If installed flush, the seal will not ride on the yoke shaft flat part, but rather on its front edge which has a chamfered edge. (12 bolt only, includes GTO, Z-28, ETC) |
Sounds like the perfect gear ratio for tree climbing
you will probably be quite happy with the standard gearing that '70 Trans Am's received 3.55:1.
JMHO. I’m very happy with my factory 355. I’d be careful telling the guy setting up my rear end how to do his job. I know what I would tell someone telling me how to do mine.
Maybe print it out and put with the rear end so the builder can say "I caught this potential problem for ya" Have seen MANY "mechanics" Disregard advice about water pump divider plates, and work had to be re done..... The good ones are always willing to LEARN, or look at options. |
Actually, the guy that's doing the work for me seems very good and so far, I trust him. If I didn't. I wouldn't let him touch the car. He's been doing this for a long time here and he has a shop that he uses for rear ends. If he/they screw it up he'll either stand behind his work or never see me again. But so far I have a good feeling about it.
