#41
This must be single stage paint?
I will assume the sealer was dry too long and should have been scuffed. That's too bad. Well, ANY manual labor, stripping, or sanding , cleaning, masking, etc. will help because Nobody wants to do it, Even at a shop rate of 80+ dollars/hour. They usually don't do much stripping or sanding in a insurance repair shop. |
#42
#43
The sealer and under it could still be good. That sealer though needs a thorough scuffing of the whole surface, then a cleaning with WB, and then Solv W&G removers.
Then use 2 tack rags on it. Sealer is usually a form of epoxy, and it can get really hard and "protective". The Base will need something with teeth on it to stay put as the clear coat will glue it all down. NO shiny spots on that sealer.. Zero.... |
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
#44
Thanks for the tips. I am sure the painter I am going to use will know what to do. But, I can use these tips when I try to paint one of my projects.
