Old 05-08-2021, 02:16 PM
tom s tom s is offline
Default speed O against odometer
OK,probably simple.My speedometer in my 62 GP is 21% off.Will that mean my odometer is 21% off.I feel it should be.Tom
Old 05-08-2021, 02:33 PM
Chris65LeMans's Avatar
Yes
Old 05-08-2021, 02:53 PM
Thanks!Tom
Old 05-08-2021, 04:02 PM
LPete LPete is offline
I’m not sure that’s necessarily true. It could be, though. The odometer is strictly a mechanical connection, so it is what it is, but the speedometer needle is driven magnetically, with no mechanical link, and the two wouldn’t have to match. Just my 2 cents.
Lee Peterson
"I didn't expect a kind of Spanish Inquisition...!"
'69 Cameo White RA III Judge, 4 speed, owned since 1977 -- my first car.
The Following 2 Users Say Thank You to LPete For This Useful Post:
Old 05-08-2021, 04:36 PM
speedo is magnetically coupled and the needle reading fights a return spring. That copper spring could have corrosion and read high.
Old 05-08-2021, 04:41 PM
I know the speedo is off because of a trans and rear end change.I have that handled just was wondering about the odometer.Tom
Old 05-08-2021, 04:58 PM
Radman's Avatar
Radman Radman is offline
With a trans and axle change everything will be off by the same amount. You can correct both by changing the speedometer gear in the transmission.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 05-08-2021, 05:31 PM
The only way to correct my trans is to make a change on the internal gear on the main shaft.I have learned to live with it.Tom
Old 05-08-2021, 05:53 PM
I think you can get an adapter to go between the cable and the tranny.
But otherwise just remember to change the mileage for MPG calculations by 21% up/down.
Old 05-08-2021, 06:25 PM
sdbob sdbob is offline
When I had 4.10s,L60 15s in my SD I got the external adapter. It worked. GM had at least 2 that I remember. I also changed the gear on the trans adapter to get the speedometer close. Since I put everything back to stk.
Old 05-08-2021, 07:14 PM
It happened when I put the 2.68 in the back.Tom
Old 05-08-2021, 07:19 PM
PontiacJim1959 PontiacJim1959 is offline
Don't know how close you live to any major interstates, but on the sides of the interstate are mile markers. These can be used to confirm you odometer as being off or not. They are typically broken down in 1/10ths, so you can sorta get an idea how much the odometers is off. I have used this to gauge mine in the past and if you don't have a GPS/MPH app on your phone, 60 miles an hour is 1 mile a minute and with your watch you can figure if your speedo is off.
Old 05-08-2021, 10:35 PM
400 4spd.'s Avatar
Plenty of interstate access in SoCal, but I don't remember mile markers during my driving experience there in '05. The 5, the 101, etc.
Old 05-08-2021, 11:07 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
Easy enough to run with someone's, 'correct speedo' for 5 - 10 miles and check it.
If it is 21% off, 5 miles should give you approximately a mile difference right?
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 05-09-2021, 02:15 AM
Formulabruce's Avatar
2.68 ! You are ready to go cross country now!
Old 05-09-2021, 06:22 AM
Jeff Hamlin's Avatar
Exclamation
I have and use a Speedo app on my phone.
No guessing...
Old 05-09-2021, 09:08 AM
Torqued Torqued is offline
Rather than changing the drive gear in my transmission,I bought this https://www.cpttransmission.com/.I called and told him the percentage is was off,and when it showed up it was dead on vs a GPS
Old 05-09-2021, 09:12 AM
that site can not be found?I have the speedo diff down pat,im not sure about the odometer yet.I have a couple gps apps.Tom
Old 05-09-2021, 09:23 AM
misterp266's Avatar
Try this Tom.
" Darksiders Rule "
Old 05-09-2021, 11:22 AM
Thanks,I have found a few sites that sell them,found a 20% unit.For me to use it I need to also install a 45 degree as my ST-10 has the speedo cable going in the pass side of the trans.Not sure if they retain the same direction yet or reverses it.Tom
