Old 05-01-2021, 01:06 AM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default Rear sway bar drop link question...
It appears there a 2 different lengths on these,,,,
Early vs late (70-74)....or small vs large bar?
Old 05-02-2021, 01:40 AM
Formulabruce's Avatar
Could be Camaros were different length. I have had a bunch, but all were same length. Same PN both sides.
I have seen them broken, and repaired with new pipe too.
All size rear bars of this era got same drop link on Birds so equipped.
A person who wanted the back jacked way up may need longer ones for their skid around a corner.....
Old 05-02-2021, 11:06 PM
The 2 on the right are the shorter ones......
They look to be a matched pair....and I see no evidence of any cobbled welds...etc...
The far left is the later style.
With the slightly shorter bar ..I guess it would mean a bit less room for diff cover access....with a transverse muffler.......
I'm going to try them on my 73.......
Old 05-03-2021, 11:28 AM
77 Canamman's Avatar
Smile
Evidently, 1974 was by itself with these, and 1975-81 had a left and right side.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 05-03-2021, 01:15 PM
Thanks...for taking the time...to look that up,
I'm assuming that the shorter ones are 74...
While we are on the subject.......Anybody have a source/ part #....for a replacement top bushing?
Old 05-04-2021, 05:57 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
I am running the rear sway bar that I removed from my 74 Formula, I will have to measure eyelet to eyelet. You think they are shorter than the previous years?
I built it one piece at a time and it cost me more than a dime.
Old 05-05-2021, 10:46 AM
Formula8's Avatar
Formula8 Formula8 is offline
My 71 has the brackets welded to the frame rail while I have seen later bars with bolt on brackets. Maybe that is the difference? The bolt on bracket decreases the space available for the drop link so it uses a shorter link??
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 05-05-2021, 10:48 AM
Bolt on anti sway bar mounts use the wrap around drop link. I have access to a friends 74, and will measure the drop links this week
Old 05-07-2021, 01:49 PM
fbody_mike's Avatar
This rear sway bar set was taken from my 74 formula. The drop link are about 10.5 inches long from center to center.
Old 05-08-2021, 09:55 PM
RamAirPwr RamAirPwr is offline
Check out post #15 from the following thread:
https://forums.maxperformanceinc.com...d.php?t=814904
1970 RAIII white/blue
Old 05-09-2021, 02:04 AM
Mine are 11 inches long. 72 originals.( rough measurements while installed)
Old 05-13-2021, 01:51 AM
In 75 they changed up to the bolt on brackets.....and the drop links used the wrap around bottom clamp with only one bolt..
