THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
This is my luck
My A/C company came out today to do the six month service on my central unit. When he went up in the attic to check the unit he found the drain pan was almost full of water. He tried blowing the line out with nitrogen but that failed. He ran a camera probe into the line and found a dead snake had not only clogged the line but broke it.
Luckily, the secondary drain line worked and kept the water level low enough that the safety switch did not energize and shut the A/C down.
Remember no one is perfect. Everyone's butt has a crack in it! |
Sounds like something that'd happen to me!
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
You could have worse luck - you could be the snake.
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
The Following 2 Users Say Thank You to Keith Seymore For This Useful Post: | ||
Your AC unit is in the attic? Mine is in the basement.
Some of us in the South don't have a basement/crawlspace.
1970 GTO (Granada Gold) - 400 / TH400 |
The Following User Says Thank You to vertigto For This Useful Post: | ||
I had that happen once- A lizard got electrocuted in the wiring in my outdoor unit. Guy cost me a few hundred bucks.
Yep. We go outside to watch our tornadoes! |
The Following User Says Thank You to 400 4spd. For This Useful Post: | ||
Clogged condensate drain is a pretty common issue. When the unit is in the attic and a secondary drain or float switch fails to shut the unit off, a lot of damage can occur. Generally the drain is clogged with debris because people don't have the units serviced on a regular basis. I will say, I've never seen a snake in one!!
My money talks to me-it usually says goodbye! |
To add insult to injury after the serviceman left I went out to start picking up yard debris caused by high winds last night during a thunderstorm. I had a small free standing swing structure that the original swing had finally decayed to the point that we couldn't sit in it anymore. Last Saturday we bought a new cedar swing and hung it until I can build a new enclosure. Well, the whole enclosure had blown over, crushed several new plants and uprooted two old clematis vines that were growing on it. Luckily (?) the new swing wasn't damaged. I tried to lift the enclosure but couldn't so I took it apart and threw it on my burn pile. I was hoping the price of lumber would go down before I had to replace it!
I guess the drain goes to ground level outdoors , and thats how the snake got into it ?
Have you taken measures to keep the next one from getting inside of it ? Maybe a pet mongoose |
The composition of the new a/c units combined with the condensate produces a live slime that grows in my drain pipe. Fortunately we keep the ac running year long so it doesn't get a chance to cause a problem. I didn't know this until my a/c guy who is also a Pontiac friend said he is seeing more and more of that.
I'm so done with Central AC in the Attic.
James Q
James Quayhagen 1963 Bonneville Safari - Nocturne Blue, 4-speed |
My central air stopped working one day and before calling a tech. I took a look at it, fuses were good...power to unit...earwig in contacts...wait what? The little sucker just happened to be crawling between the contacts just as they closed. I removed the bug and it worked fine after. I probably saved some money on a service call.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
Yes, the primary drain exits the house just above ground level. And I have posted no trespassing signs in the flower bed that the pipe drains into! But just to be sure I wrapped the end of the pipe with screen cloth.
Does anyone in the south have a room dedicated to the a/c and heat and water tank so it’s not overhead? I live in Ohio so all are in the basement.
I had a large spider short out the control board on my outside unit. I guess he was just conductive enough. It cost me a couple hundred dollars, and him his life.
Occasionally, one will run across a builder down here installing central heat & AC unit in the attic. The last few years have ran across a few retrofits of central heat & AC units into the attics of near 50 year old homes, mainly in starter sized homes. In every case, the millennial first time home owners thought it was a good idea to move the unit up into the attic. I'll never get that.
In NC, new homes on a slab usually have the water heater in the garage and air handler in the attic. They've (mostly) stopped putting the water heater in the attic and air handler in a closet.
