updated list of 70-81 trans am parts
all parts pulled from 70-81 trans am or firebird. located in vassar MI. I will ship through usps for small parts and fastenal for larger parts. call/text 8108754154 email thefbodygarage7081@yahoo.com
Rack 1 Shelf 1 79-81 door panels 60.00/pair Rear package tray 35.00 70 only rear seats 100.00 70 black vinyl front and rear seat covers 250.00 Rack 1 Shelf 2 70-72 upper fender brace 75.00 each Rack 1 shelf 3 Flywheel 75.00 Rear alternator bracket 45.00 Exhaust block off valve 35.00 Dip stick 25.00 Valve cover tube 70-76 20.00 Positive wire loom 20.00 73-79 ac bracket set 200.00 F2 throttle bracket 80 amp alternator and power steering bracket 100 New power steering lines 15.00 70 throttele bracket 40.00 80 amp alternator power steering bracket set 100.00 Flexplate 60.00 70 ram air 3 valve cover drippers 100.00/pair Choke tube 40.00 Distributors 1112923 6d2 40.00 1112928 5c20 40.00 1112495 5c14 40.00 1112928 5b25 40.00 Rack 1 Shelf 4 80 amp alternator 60.00 New CVR mini starter 125.00 Valve cover 60.00 Power steering resivior caps 10.00 71-74 throttle cable bracket Alternator bracket 499749 40.00 Alternator bracket 482254 40.00 Ground cable 5.00 Ground strap 5.00 Valve guides 50.00/set Distributor hold down 10.00 Flexplate brace 40.00 71 only power steering brackets 100.00 Crank pulley reinforment 10.00 72-81 power steering bracket set 60.00 71-81 water neck 10.00 67-70 water neck 15.00 Fuel eccentric 20.00 Lift loop 10.00 Exhaust heat shield 30.00 Coil bracket 15.00 Rack 1 Shelf 5 70-74 rear glass 60.00 48296 water pump 25.00 Ac condenser 40.00 Rack 1 Shelf 6 6x-8 heads 100.00 A/C compressor 80.00 Ram air 3 12 heads 800.00 Rack 1 Shelf 7 6x-8 heads 100.00 46 heads 100.00 7k3 heads 100.00 Rack 2 Shelf 1 78-81 trans am seat set 100.00 Rack 2 Shelf 2 70 only seat belts black 350.00 72 seat belts blue 600.00 75-77 seat belts black 250.00 78-81 seat belts black 250.00 Rack 2 Shelf 3 Timing chain covers 9796346 100.00 527292 75.00 526985 40.00 482883 75.00 Full length windage tray 60.00 ¾ length windage tray 50.00 EGR valley pan 100.00 Non EGR valley pan 100.00 Rack 2 Shelf 4 78-79 ws6 air ckeaner housing 350.00 71 2 barrel air cleaner housing 80.00 Water pump pulley 481039 xf 40.00 9799128 xt 75.00 9799127 xf 75.00 10004850 yy 40.00 481040 xt 40.00 Crank pulley 481037 ya 40.00 481038 yb 40.00 9790842 yb 40.00 480509 xs 20.00 Power steering pulley 493243 60.00 481042 xd 60.00 496411 yp 40.00 80-81 301 turbo alternator bracket set 60.00 80-81 301 turbo power steering set 60.00 80-81 301 turbo harmonic balancer 60.00 80-81 301 turbo pulley set 100.00 Rack 2 Shelf 5 75-81 motor mounts 100.00 Oil filter adapter 50.00 Carbs 7043263 200.00 7042274 100.00 7041264 100.00 Holley 80457 600 cfm 50.00 Intake 481733 o100 200.00 Rack 2 Shelf 6 Intake 9799068 I199 150.00 525355 Eo77 50.00 525355 A217 50.00 525355 D026 50.00 9794234 J038 150.00 10003395 H307 150.00 496140 H234 50.00 Rack 2 Shelf 7 Engine blocks 400 488988 yt L064 400.00 488988 yx E302 400.00 488988 yt F194 400.00 500557 YA H167 250.00 Rack 3 Shelf 1 78-81 trans am seat set 100.00 71-81 camaro seat set 100.00 Rack 3 Shelf 2 71 firebird fender cut outs with vents 100.00 70-71 carpet guard 25.00 70-72 cener core support brace 200.00 70-71 door hinges 75.00 70-73 valvance fender brackets 200.00 70-73 master cylinder with bleeders 40.00 73 grills 100.00 70-71 grills 100.00 Misc ac parts for 70-73 Rack 3 Shelf 3 71 firebird fender vents 60.00 70-71 door panel brackets 100.00/set 70-73 fuel door 30.00 70-72 parking lamps 100.00 70-73 parking lamp fillers 50.00 70-73 horns 60.00 70-73 tail panel cover needs some work 125.00 Non power brake master cylinder rod 20.00 71-74 seat tracks for one seat 100.00 70-76 heater control bracket 15.00 70-72 firebird dash bezel with rings no gauges with ac 150.00 70-72 firebird dash belzel with rings gauges and ac 300.00 70-72 firebird dash bezel with rings no gauges or ac 200.00 Rack 3 Shelf 4 70-73 headlight plates 60.00/pair 70-73 headlight plates with buckets 100.00/pair 70-73 pinion bump 40.00 Pontiac tail panel letters 25.00 70-73 console seat belt clips 25.00/pair 70-71 wiper switch 20.00 70 only rear end bump stops 125.00/pair 70 only washer jug cap 20.00 70-73 rear spoiler ends 150 .00 73 grill brackets 80.00 70-72 grill brackets 60.00 70-73 taillights 100.00 70-72 side headlier trim 100.00/pair Center valance bracket 35.00 Core support plate brackets 80.00 72-74 motor mounts 200.00 70-72 hedliner bow set 150.00 Rack 3 Shelf 5 70-72 nose cone 300.00 70-78 spoilers 400.00/set 70-73 main L brackets 200.00/pair 70-73 small L brackets 60.00/pair Rack 4 Shelf 1 78-81 seat set 100.00 Rack 4 Shelf 2 Oil pan 60.00 Sail panel 100.00/pair Rear arm rest 100.00/par 70 only rear arm rest 125.00/pair Rack 4 Shelf 3 Steering column cover 50.00 Glove box door 50.00 Cigarette lighter 20.00 Visors 60.00 Visor bracket 10.00 Dash bezel emblem 10.00 Seat belt covers 50.00 Dash grab bar 10.00 Dash prism 25.00 Steering wheel black 125.00 Rack 4 Shelf 4 Ac heater core box 25.00 79-81 air dam 100.00 74-75 header panel 100.00 Rack 4 Shelf 5 Rear arm rest 150.00/pair Sail panels 150.00/pair 403 fan shroud 100.00 Rack 5 Shelf 1 Wiring 79-81 taillight 25.00 Heater only control wiring 35.00 Dash courtesy lights 25.00 77 TA Pontiac 400 no ac no power doors complete 250.00 77 TA Pontiac 400 4 speed complete 250.00 78 TA Pontiac 400 auto no power doors ac complete 250.00 Antenna wire 15.00 77-78 headlight harness 30.00 Dome light 20.00 Shifter light 20.00 77-78 ac 35.00 70-73 ac 50.00 79-81 ac 35.00 Intermediate wiring 20.00 77-81 power window power lock complete 100.00 Rear defrost 20.00 Cruise control complete 150.00 74-78 taillght 35.00 Deklid courtesy light 25.00 Camaro non ac 20.00 Camaro ac 20.00 70-72 headling harness 100.00 Ashtray 20.00 Rack 5 Shelf 2 70-78 tilt column 250.00 70-78 non tilt column 100.00 79-81 camaro non tilt 100.00 79-81 tilt column 200.00 79-81 non tilt column 100.00 Front seat back plastic 20.00 Rack 5 Shelf 3 70-71 160 mph speedometer 100.00 72-76 160 mph speedometer 100.00 Map pocket 40.00 100 mph speedometer gold line 40.00 72-79 6k tach 100mph speedo cluster 200.00 74-79 new printed circuit 40.00 81 pace car gauge set 250.00 79 10th anniversary gauge set 250.00 Gauge bezel 20.00 80-81 volts fuel gauge 25.00 75-79 volts fuel gauge 25.00 71-74 volts fuel gauge 100.00 70 only volts fuel gauge 125.00 70-71 ac controls 100.00 72-76 ac controls 100.00 Headlight switch 10.00 70-76 ac cable 40.00 70-76 non ac cables 100.00 77-81 ac cable 25.00 77-81 non ac cables 100.00 Rack 5 Shelf 4 78-81 arm rest door pulls 100.00/pair Clothes hanger hooks 10.00/pair Red bird shift knob 30.00 Gold bird shift knob 50.00 4 speed shift knob 60.00 Brake release handle 15.00 78-81 t top clips 10.00 each 78-81 t top trims 40.00 each Horn button 50.00 72-77 armrest pad 10.00 each 80-81 front speaker grills 40.00/pair Seat belt triangles 10.00 Seat hinge cover 20.00 Dash bezel ring set 35.00 Console back plate 10.00 NOS fan switch 20.00 Cigarette lighter nut 5.00 Wiper switch 10.00 Gold defrost switch plate 40.00 Silver defrost switch plate 10.00 Silver delete plate 10.00 70-72 firebrid defrost switch plate 60.00 73-76 firebrid defrost power window switch plate 60.00 70-81 trans am defrost and power window switch or audio boost plate 60.00 70-77 radio 250.00 70-73 defog switch 125.00 74-76 defog switch 100.00 77-81 defrost switch 60.00 70-76 power door lock switch 120.00 77-79 ac controls 75.00 77-79 non ac controls 75.00 80-81 ac controls 75.00 80-81 non ac controls 75.00 Rack 5 Shelf 5 Hood hinges 71-81 40.00/pair 72-77 upper door panels 125.00/pair Rack 5 Shelf 6 Door glass 20.00 77-78 front lower spoiler 75.00 Rack 6 Shelf 1 73-81 inner fenders 35.00 each 70-72 inner fenders 60.00 each Rack 6 Shelf 2 Kick panels A/C 75.00/pair Kick panels non A/C 75.00/pair Rack 6 Shelf 3 77-81 seat track covers 5.00 each Center console box 65.00 Untested 100 mph 6k tach gauge cluster 100.00 Gauge cluster pigtail 74-79 15.00 Glove box insert 10.00 Hush panel 40.00 Horn contact 20.00 Dash bracket. 10.00 Rack 6 Shelf 4 Gold dash bezel restored 200.00 Silver dash bezel 50.00 Ac dash vents 35.00 Shifter plate 25.00 Rear speaker grills 60.00 72-77 door panel bracket 15.00 each Shifter 60.00 Bump shifter 100.00 73-81 side headliner trim 100.00 Rear floor pan seat bracket 20.00 each Ash tray 20.00 Steering wheel hub 30.00 Rack 6 Shelf 5 Carpet guard 10.00 Ac crotch duct 75.00 Ac behind radio duct 75.00 Passenger side ac duct 50.00 Rack 6 Shelf 6 72-77 lower door panels 125.00/pair Power door boots 20.00 each 73-81 a pillar trim 30.00/pair Rack 6 Shelf 7 Radio cut out repair section 25.00 Center console 40.00 Gear box 30.00 Rack 7 Shelf 1 78-81 camaro rear bumper 60.00 77-78 rear bumper 75.00 Rack 7 Shelf 2 Ac Y duct 20.00 Non ac Y duct 35.00 Non ac cowl to vent set 60.00 All other ductwork 15.00 each Rack 7 Shelf 3 71-81 windshield trim 100.00/set 75-81 rear window trim 100.00/set 78 grills NEW 200.00 Rack 7 Shelf 4 Fischer t top bags 100.00/pair Jamb vents 10.00 each 77-81 eyebrow trim 20.00/pair 71-76 eyebrow trim 40.00/pair Stainless trim on top of door 50.00 each T top handl 40.00/pair T top handle firebird logo 100.00/pair Rally 2 center caps 20.00/pair Rear arm rest ash tray 10.00 each Remote mirror handle bezel 10.00 Window cranks 10.00 Fischer t top hold in brackets 40.00/set B pillar trim 40.00/set 77-81 power door lock switch 15.00 Door lock nobs 5.00 each Fender chrome tips 40.00/pair Shaker ring 40.00 Rack 7 Shelf 5 301 turbo exhaust manifolds 300.00 70 ram air 3 exhaust manifolds 700.00 All other manifolds 100.00 4 core auto radiator 60.00 Rack 7 Shelf 6 77-81 AC suitcase 100.00 74-76 AC suitcase 100.00 70-73 AC suitcase 200.00 Space saving spare tire 125.00 Space saving spare tire inflator bottle 50.00 Rack 8 Shelf 1 71 firebird driver side fender 150.00 77-81 firebird fenders 75.00 each 77-81 trans am fender 200.00 Driver side toe pan 60.00 Rack 8 Shelf 2 79-81 taillights 200.00/set 74-78 taillights 50.00/set Rack 8 Shelf 3 73-81 4 speed pedals 80.00 Bellhousing 9785581 150.00 Chevy bellhousing 3840363 75.00 70 trans am shaker with base 1200.00 4 speed fork 20.00 Z bar 40.00 Z bar bracket 10.00 Ball stud 10.00 Rack 8 Shelf 4 70-74 th400 crossmember 80.00 70-74 th350 or 4 speed crossmember 100.00 75-81 crossmember 40.00 77-81 reverse lock out drive set 60.00 Trans dipstick and tube 15.00 Shift bracket 20.00 75-80 catalytic converter bracket 40.00 81 catalytic converter bracket 100.00 Th400 shifter cable pan bracket 20.00 Th350 shifter cable pan bracket 20.00 Auto dust cover 30.00 Shifter cable 10.00 Rack 8 Shelf 5 79-81 flares 40.00 each Rack 8 Shelf 6 74-78 rear spoiler ends 75.00/pair 70-81 middle spoiler 30.00 79-81 rear spoiler ends 50.00/pair Rack 8 Shelf 7 12 bolt axles 60.00 Disc brake axles 60.00 Cowl screen 15.00 Jack setup 150.00 Rack 9 Shelf 1 70 only core support 100 .00 77-81 core support 100.00 77-78 nose complete 250.00 74-81 new quarter panels 120.00/pair Rack 9 Shelf 2 3 piece cold air intake ducting no flex line 100.00 Intake elbow for 301 20.00 77-81 301 3 piece set with 3” flex hose 100.00 78-81 301 shaker 125.00 77-81 301 3” elbow 20.00 Rack 9 Shelf 3 Door handles 10.00 Kick panel ac actuator 20.00 77-81 headlight trim 25.00/set 74-81 rear sway bar bracket set 25.00 74-81 rear sway bar drop links 40.00 74-81 pinion bump 10.00 74-81 rear end bumps 15.00 each 77-81 headlight buckets 40.00/set Marker light bezels 10.00 each Gasket channel for door 35.00/pair Marker lights 60.00/set Window motors 100.00/pair Rack 9 Shelf 4 Shock plates 15.00/pair Ta fender vents 50.00/pair New kyb shock set 50.00 Door/ body plugs 5.00 each Side mirror brackets 15.00/set 77-81 core support middle bracket 15.00 79-81 headlight bezels 60.00/set Power trunk lock button and actuator untested 25.00 Windshield hold ins 10.00/pair 74-78 license plate light lens 15.0/pair Ws6 subframe braces 40.00/pair 74-78 gas cap 10.00 Non ac heater core brackets and filler 20.00 Radiator bumps 10.00/set Hood latch 25.00 Hood spring 10.00 77-78 hood latch cable bracket 40.00 79-81 hood latch cable bracket 30.00 Rack 9 Shelf 5 Non ac blower motor housing 20.00 Trunk latch 10.00 74-78 fuel door 30.00 Inner fender brackets 15.00/pair 79-81 grills 75.00/pair Radiator hold ins 5.00 each Gas tank straps 10.00 each Side mirrors 75.00/pair 75-81 throttle cable 15.00 77-81 core support to fender braces 40.00/pair Gear box cover 15.00 Parking brake 20.00 77-81 inner fender extensions 50.00/pair Leaf spring pockets 40.00/pair 74-81 horns 40.00/pair Rack 9 Shelf 6 Speedo cable 10.00 Brake pedal 20.00 1 ¼” front sway bar 65.00 Rear sway bar ¾” 65.00 Rack 9 shelf 7 70-76 intermediate shaft 35.00 Under sill wire guards 65.00/pair Decklid torsion rods 40.00/pair 73-81 front and rear headliner trim 40.00 Filler panel between rear glass and decklid 40.00 4 speed or th400 driveshaft 125.00 Th350 driveshaft 65.00 Rack 10 Shelf 1 Rally 2 rims 15” 100.00/set Camaro N90 rims 15” 500.00/set Rack 10 Shelf 2 70-73 front valance 150.00 Chevy rally 1 rims 7” 150.00/set Chevy rally 1 rims 8” AZ corvette rims 250.00/set 7” snowflake rims 150.00/set Rack 10 Shelf 3 Decklid 75.00 75-81 doors 100.00 each Rack 11 Shelf 1 Power window regulators 35.00 each Manual window regulators 35.00 each Window tracks 10.00 each piece 76 bumper brackets 50.00 74-75 bumper brackets 50.00 Wiper transmission 20.00 Wiper arms 20.00/pair Other Brake booster 20.00 Th350 75.00 Th400 125.00 200r4 150.00 77-81 shaker hood needs minor work 100.00 77-81 formula hood 100.00 77-81 firebird hood 40.00 75-81 rear glass 50.00 Misc. trim 10.00 each 308 posi disc brake rearend 300.00 323 posi drum brake rearend 250.00 71 subframe 100.00 79 ws6 subframe 100.00 70-72 nose 50.00 79 nose 80.00 75-81 passenger side full length floor pan new 100.00 71-75 formula hood 250.00 79 z28 hood 75.00 Driver side 78-81 z28 fender 100.00 Camaro inner fenders 75.00/pair New 74-81 right rear frame rail section 100.00 |
Distributor
Do you still have distributor 1112495?
PM sent
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
You got any rear disk brake caliper lever return springs
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
This post is 7 years old, Woogie hasn't been here in 5 years. He's on ebay, so good chance most of this stuff is now gone but replaced with different stuff.
Do you know what his store name is on ebay?
