4 Speed Shift Linkage GTO/Chevelle?
I'm trying to figure out the interchangeability of some shifter linkage.
I bought a shifter several years ago that I was told was for a mid '60s 4 speed GM(1st picture). Just to look at it, it appears very similar to a '66 GTO shifter that I had in the past. The other day I bought a 4 speed shifter that is supposed to be from a '66 Chevelle. Neither of these had any linkage with them when I got them. After I picked up the Chevelle shifter, I mentioned to my neighbor I had a growing collection of shifters but no linkage and he said "I've got some extra linkage that I would sell from the '66 Chevelle I had years ago." Would the linkage for these two shifters happen to be the same? Just trying to decide if I should put it on the "someday" shelf with the GTO(?) shifter or put it with the Chevelle shifter when I resell it.
"What the hell's wrong with freedom man? That's what it's all about." (Billy) "Oh yeah, that's what it's all about alright... but talkin about it and bein it, that's two different things." (George) Easyrider |
it seems pontiac is pontiac
olds is olds chevrolet is chevrolet for linkage and levers and shifters very little interchanges ,,, yah there is a couple things but from what I have owned 95% is specific to the car and year and model and trans used ,,, mounting plate ... levers etc Scott |
The Following User Says Thank You to Scott Thelander For This Useful Post: | ||
Linkage Compatibilty
I'm not an expert, but I believe it depends on the shifter. If the shifters are different, then no - they will not interchange.
GTO Hurst stick Chevelle Muncie stick |
The Following User Says Thank You to shifty For This Useful Post: | ||
I was afraid that would be the case. But, I figured I should ask since all the shifters I have installed have been aftermarket and specific only to the transmission.
I have recently delved into this;
Apparently the reproduction stuff that Inline Tube makes is patterned after 1969(?) GTO parts - they sell it as a one size fits all. I have found that there are three distinct variables for anything: 1) shifter plate - (forgetting the shifter handle receiver for a moment) this positions and angles the shifter body 2) shifter arms (transmission mounted); this plays key in the length and shape require for the rods 3) rods - generally unique for a given application; I believe that GM tended to stamp shift rods after (about) 1966 - but in my experience, even rods made after that may not have any stamping, or an abbreviated part number - or even the last digit in the rod's part number. I think it all plays together because the consoles being division specific required the shifter "pop out" in a specific spot. This one made me chuckle just yesterday; The following image is of three Muncie three speeds - they are the same length as, and use the same shifter brackets as all pre-1970 GM four speeds. The red arrows are pointing to the rear/lower shifter bolt location - lok at it's relation to the transmission's output! The bottom one I just got, and found that it's more or less useless to me at this time - I cannot even mount an OEM shifter to it! LOL.
The Following User Says Thank You to unruhjonny For This Useful Post: | ||
??? hmmmmmmm |
/\ the large output Muncie four speed first showed up in 1970, and was used for 1971+ cars;
The large output four speeds used a different shifter bracket, because of different mount boss locations, and is shared with the 1973+ BW-ST10. I believe that the saginaw retained the small output, but do not know if the shifter mount bosses changed. Oh! And I just found out last night that the lower shifter bracket in that picture is sold by Hurst as being for a 63-67 Corvette with a Muncie
