'66 B body safe-t-track repair Texas
I have a safe-t-track rear end I took out of a 1966 GP 20 years ago and it had been sitting in a junkyard for ?? years before I got to it. I now want to install it but would like someone to go through it before installing.
Does anyone have a suggestion for a competent shop in the Houston/Austin area? |
Houston DriveTrain Service... I've used them in the past and wasn't disappointed.
I have had great luck with Pyle Brothers in Baytown.
http://pylebros.com/ They do a lot of drag and dirt cars. Pricing has always been fair. Mike |
if its not rust damaged and gears wear pattern/spiders looks clean nice just run it... sitting idle 30 years oiled is a good thing... mint !
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
I plan to open the unit this week - and if it looks decent, I may simply install it and go from there. But if not, I at least have two Houston-area shops to consider. First thing I will look for is a tech with lots of grey hair............
Biggest issue with those rear axles is failed axle shaft bearings. I would remove the shafts and inspect and roll the bearings. If they are absolutely smooth, and no metal is found in the housing, I would clean it out, put fresh lube in it and go. Then change it again some day when the lube is hot, say after 300-500 miles. The gears, and posi units are really very reliable.
The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
